lots of FV rode to Harewood and Mosport in the BED of pickup trucks way back when
Barry Wilcock
A tip for car owners with carbs and towing......after you load your car up and are ready to drive off to the track.......start your race car up and run a minute, then shut off, then tow......
here's the idea........if your car has sat a long time, you push it onto the trailer and drive away.......your float bowl is empty.......as you drive along / bump along..........think about what's going to happen to the floats in the bowl......
their adjustment may become altered by their flopping around
if they flop around less because they're in a bowl full of gas, they just might be still at your desired setting when you arrive at the track
looking for tenths?????
The U Haul car haulers are really heavy. They are designed to safely and efficiently haul heavy full size street cars, so probably not good to tow behind most cars/small SUVs even empty. I used to rent one when I raced an Rx7. Normally, the rate back then was around 50.00/day. Talk to the manager at the U Haul place, as I was able to get them half price, as long as I dropped it off at a different location than the one that I picked it up from. They took up a lot of space, and the manager didn't want too many around, because he could use the space for a higher profit item to be parked at his store.
I also have heard (may be a wives tale) never to tow with the race car in gear. Tie it down and the tow in neutral, because the back and forth motion , if the car is in gear, is moving the pistons up and down a little, with unoiled rings....shortening engine life. Maybe a little gearbox internals wear as well. Also, my shock guy says that towing shortens the time between shock rebuilds.......if you are not compressing the shocks on tie down. Tie down to prevent forward and back motion, keeping the car as close to normal ride height as possible. he says towing with an improper tie down, allowing the suspension to travel, can have the effect of driving the car the same distance... Also, remember that any tow vehicle can stop with a lot more force than it can accelerate, so keeping the car from moving forward is more important than from moving aft in/on the trailer.
sounds like another good reason to FIT a different engine
If you buy a used trailer, please consider new tires and a spare before the first out of town trip. Always, always, always. It will save a lost day of racing.
It's not always possible but try to have the loading on each tire by no more then 60% or 65% of the tire's load rating. Most trailer tires will not live long when loaded over 85% of their rated weight. Especially crossing the desert.
Examples:
1. The tires on my street BMW run 4 to 5 degrees above ambient outside temperature at 80 MPH. Your unloaded car may be about the same.
2. My 6000 lb 4 wheel box trailer on 2840 pound per tire ratings ran 21 degrees above ambient temp at 75 MPH.
3. The 11000 lb box trailer on 2840 pound tires ran 47 degrees above ambient at 65 MPH. 10 more MPH adds 10 degrees to the tire temps.
If the outside temperature is 112, trailer 3 crossing the desert at 75mph will give sustained temperatures up to 169 degrees. Not good for Chinese manufacture tires.
If it's cold you can get away with pushing the tire loading envelope. Beware of Texas and Arizona, Ha.
Keep having fun,
Jim Edmonds
And re-pack or replace the wheel bearings !
pride of ownership ya da Ya Da YA DA
may be time to rethink all of this and just rent cars at the track, hopefully ones near mass rapid public transportation....just saying
Agree about DO NOT TOW WITH CAR IN GEAR
Tie the car down, gas in float bowl, make sure car is in neutral, at least one wheel chocked too
And after you've fired the car up to fill the bowl TURN YOUR IGNITION AND CUT-OFF SWITCHES OFF
I've heard stories of people who put a small air bag/cushion under the car after it's tied down and inflate it to the point where the car is raised just a tiny amount from the "just sitting there ride height"
and especially for my formula cars when they're in the enclosed trailer.....I never roll the car's windows up.....I made that mistake once.........it took me days to get them back down
