Results 1 to 16 of 16
Thread: shock dyno
    Roanoke, Virginia
    Default shock dyno
    Anyone know where to get a rear shock dyno tested?
    Senior Member mmi16's Avatar
    Liked: 310
    Quote Originally Posted by Mitchell Ferguson View Post
    Fred Clark - Caracal Cars
    904-234-5603
    Rear Shock, Front Shocks - all shocks - big and little. Penske and others.
    Belvidere,Il
    Liked: 76
    Lindstrand racing in Darian ,Wi. 262-724-3346
    Has to be about a hundred shock dynoes in Charlotte area- not that far from you.
    butch deer
    near Athens, GA
    Liked: 860
    Mitch,
    You might check with James at Stimola Racing Products (www.srpengineering.com). They MIGHT come to the Atlanta Majors ??
    Bradenton, FL
    Liked: 14
    Kris at k-hill motorsports does shocks in Abbotstown PA
    -Head MRTI Indy Lights Mechanic: -Head SCCA USF4 Mechanic
    -Lead Cape Motorsports Mechanic: -Head PWC Audi R8 Mechanic
    -Lead IMSA LMP2 Mechanic
    Liked: 4363
    904-234-5603
    Roanoke, Virginia
    Awesome guys!
    Duncannon, PA
    Liked: 300
    Default shock dyno
    Hi Mitchell, I would highly recommend RE Suspension www/resuspension.com and they are located in Charlotte area. I first meet them at VIR many years ago and have used them since. I was really impressed by how the owner Butch listened to my questions and thought about it before coming up with an answer. They work with all types of motorsports and have a vast knowledge of suspensions and might provide different solutions to any problems you could have.
    Ed
    Guadalajara, México
    Anyone with a rear shock dyno chart???
    Duncannon, PA
    Liked: 300
    Default shock graph
    You might want to not try to compare dyno information because if you don't have the same or very similar suspension layout it would be like comparing apples to oranges. There are quite a few different types and styles of zero roll systems on FV cars.
    Shelbyville, TN
    Liked: 94
    Here you go. Don't forget as Ed said the motion ratios are different for each car.
    Scott
    Indianapolis Indiana
    Default Shock Dyno
    Send it to me in Indy if you don't find anyone close to you,
    Liked: 293
    Mark Edwards (FV racer) has a shock dyno on the West Coast.
    Belvidere,Il
    Liked: 76
    Penske Shocks can develop shocks for you. Check this out.
    http://www.magneshocks.com/Documents...alRoadRace.pdf
    butch deer
  16. #15
    Guadalajara, México
    Quote Originally Posted by Diamond Level Motorsports View Post
    Is this chart from a good shock?
  17. #16
    Shelbyville, TN
    Liked: 94
    Quote Originally Posted by enrikerace View Post
    Not completely sure what you mean by that.
    This chart represents a Penske 8300 with the upgraded compression adjuster and canister. I would consider it state of the art for FV.
    Scott
