Page 6 of 7 FirstFirst ... 234567 LastLast
Results 201 to 240 of 258
  1. #201
    Me and Cal.
  2. #202
    Dave Piontek and me.
  3. #203
    Livonia, MI
    Is this one of those contests where you make a caption for the photo? Something like:
    Jay: Where does the invisible supercharger go?
    Dave: Right about here.
    Seriously though, the car looks very nice.
  4. #204
    Atlanta, Georgia
    The old man pretending he is a hero driver.
    In this photo, is the drivetrain fully installed? I ask because I don't see any part of it.
    With our Scorpion's bodywork, which is roughly similar to yours, we had to cut a big hole on top behind the main hoop for the MC. It needs the hole anyway to let the hot air out quickly.
    Redford,Michigan
    Default SCORPION
    Jim, does you engine sit up that high ,or is it to clear the intake stacks?
    Dave
  6. #206
    Atlanta, Georgia
    The MC is lowered as far as possible with a 2.5" tall oil pan but the top of the injectors along with the OEM air box still stuck up above the bodywork, thus, the need for the hole. The hole does help to exhaust the heat.
    Quote Originally Posted by jim murphy View Post
    Yes, the engine is in there Jim. Our own air box is not shown yet but you will see it when we hit the track.
  8. #208
    Romeo, Michigan
    body #2 delivered today - #3 is in process
  9. #209
    Member sportech's Avatar
    Brighton, MI
    Default NovaBlade Car #2
    Here is Car #2 with the body in place. It dropped right on with only minor sanding to clear a weld. Fitting the body on the build table makes it very easy to set the correct heights for the side pods and nose. Jay is praying that it all fits together. Nice parts Mike!
    Dave Piontek
  10. #210
    Something else for your viewing pleasure. Not an F600 but related.
  11. #211
    Big Canoe, GA
    Liked: 38
    Is that going to be another electric hill climb car?
    Crossle 32F, Piper DF5 Honda
  12. #212
    GingerMan Raceway, Michigan
    Liked: 14
    Jay I'm digging the Western Broncos shirt you are wearing, I thought you were straight up Wolverine..... cool.
  13. #213
    Courtice, Ontario, Canada
    Liked: 144
    What engine?
    Stephen Adams
    RF92 Van Diemen FFord
    1980 Lola T540 FFord
  14. #214
    St. Louis, MO
    Liked: 110
    Default Engine
    I'm betting 1000cc bike motor and a full fendered body.
    Marty
  15. #215
    Liked: 144
    I thought 750 cc and heading to Canada...F4.
    Stephen Adams
  16. #216
  17. #217
    Default Chris Ross F600
    We just delivered Chris Ross's brand new Nova Blade to him today and he is on his way back to North Carolina. Complete car weight just under 600lbs without fuel or water.
    Now back to prepping the other cars we are building. We should be testing with Calvin Stewarts car and ready for testing by the end of Feb.
    Car #3 will be ready for pickup next weekend. Then on to building the next 2 cars of our 5 car production run.
  18. #218
    Quote Originally Posted by old 59 View Post
    Stephen, we would be very happy to build you an F4 version with springs and shock with a 750 Suzuki which fits exactly on the same mounts.
    I wonder how fast it would be with 150hp with wings and a ready to race weight of 600 lbs?
  19. #219
    Dearborn
    Default All sold
    Hi Jay. Do u haven all five sold...I know the first 3 are gone how about last 2 cars .are they spoken for?
    Mo
  20. #220
    Delete
  21. #221
    Just a couple of additional pics.
  22. #222
    Rear axle detail
  23. #223
    Another
  24. #224
    Chris & his new Blade.
  25. #225
    Atlanta, Georgia
    I heard that Chris dashed into your shop between two nasty winter fronts - lucky guy!
    Cleveland, OH
    Liked: 131
    Default Announcing the new Nova F600 Blade
    We just refer to that period as "winter" in the northern states.
  27. #227
    Front susp detail.
  28. #228
    Dave's F600 headers just sitting in the engine compartment.
  29. #229
    Livonia, MI
    Front susp detail.
    Does this make camber/caster alignments adjustable only by 1/2 turn of the rod ends on the A-Arms?
    Or another way of asking, what is the smallest adjustment to caster and camber that can be made with this configuration?
  30. #230
    Quote Originally Posted by bimmer635csi View Post
    Yes Chris you are correct. The front suspension does not have shims for camber adjustment. I tried to do it with shims but could not due to package issues. The camber change for 1/2 turn of the outer rod end is .28 deg. Of course this camber adjustment requires an adjustment to the toe but we know how many flats on the tie rod gets the toe right where it is supposed to be so it is actually a very easy adjustment. There is an adjustment that allows for much finer camber adjustment but I think that about 1/4 degree is good enough.
    Of course I could have designed it so that shims could have been used for finer adjustments of camber but I decided that it was not worth the extra costs.
    In fact most current F1 cars also separate the camber and the toe but both are adjusted separately with shims for both adjustments.
  31. #231
    Powhatan, Va
    Default air box
    I did not see the pressurized air intake on any of the bodywork. Is it still part of the design? Is there even the most remote chance that the bodywork can be adapted to my Novakar?
    Ken Van Horn
  32. #232
    We will have a purpose built airbox and will show it when we debut the car.
    I really doubt if the body could be adapted, but we could try.
  33. #233
    What about just adapting the air box to existing Novakars?
    Chris Ross
  34. #234
    Quote Originally Posted by lancer360 View Post
    Most likely doable. Working on the tooling now.
  35. #235
    Raleigh, NC
    Default Where in NC?
    OK, Jay, inquiring minds want to know where in NC Mr. Ross lives! As one of the Novakar "founders" (think, Epee – saw the pic of you and Dave – Man, we look old now!), I'd love to go see the latest from the brain trust.
    Now that I'm finally getting my Prod car back together, you go and build some of these!
    Rick
  36. #236
    It is in my profile. Charlotte, NC.
    Chris Ross
  37. #237
    You would be a tough fit Rick. Possible but we would need to find every inch possible.
  38. #238
    Boca, FL
    What's the overall length with the full body in place?
  39. #239
    NY
    Quote Originally Posted by Jack A. View Post
    From the GCR:
    Overall Length: Minimum 110”
    Maximum 150”
    Overall Width: Minimum 50”
    Maximum 55”
    Weight: see spec line at end of
  40. #240
    Off the top of my head I do not know the exact length of the Blade body. It is around 140"
There are currently 7 users browsing this thread. (0 members and 7 guests)
