Hello,
Does anyone know if the cockpit adjuster for the adjustable swaybar needs to be a SCCA enterprises part or could I use something like this:
https://www.pegasusautoracing.com/pr...p?Product=3462
Robin
Hello,
Robin
Not sure on the legality, but you might also use something like this:
http://www.gyrodynamics.net/swaybaradjuster.htm
The main problem with the vernier adjuster (which is basically a mixture control knob off a light aircraft) is that it isn't repeatable. You can quickly move the cable by pushing the central button which removes the friction lock but you have no positive stop to insure you are going to the same spot everytime except full hard and full soft.
Charlie Warner
fatto gatto racing
What Charles said.
I don't believe it's "open" to purchase it from anywhere or to home brew your own. Maybe one of the CSRs can chime in...
2003 VanDiemen FSCCA #29
Keith, the adjustable front sway bar is a spec item.
Mick Robinson
Thanks, Mick. Yep, I figured as much.
Thank you for the information gents!
