Hi I broke a rear centre locking bolt(its the rear bolt threaded on each end holds the wheel on). Can anyone tell me who stocks or makes this kind of thing.
Pics
I think there are a number of sources that probably make them for other cars. From memory, when I was a Tiga importer its a regular 3/4 threaded stub axle as is most of the UK built stuff. Post some dimensions and I'm sure someone will go and look at what they have and give you an idea of where to start - Fast Forward probably.
phil
I will PM you about a Dymag wheel I have that may fit your car.
Second Fast Forward. Doug's stuff is fairly priced and bulletproof.
If he doesn't have them he will know where to get them e mail
r_andreason@msn.com,
Thanks guys i'll give them a try.
TDI (Two Dogg Inc, or Taylor Design - John Taylor), can make them. He made a run for me of the RT-4 stub axles that were threaded 3/4 fine on both ends. Get your measurements and they might be close enough to the Ralt versions that you could use one of them. There are some after-market axles floating around that have cut threads that are very sharp and prone to breaking. Make sure the units you get or have made have rolled threads.
Charlie Warner
fatto gatto racing
