    Senior Member reisertracing's Avatar
    indiana
    Post
    I was wondering if anyone had a quick and easy suggestion for fuel sample ports. I bought one from Pegasus and I am wondering where to connect it. They suggest on an open port on the fuel regulator( is there one?). I have a Citation FC that was Ken Stivers and I am planning on going to IRP this week and race.
    Any thoughts on if tech will not pass me if I don't have the port in place for my annual. I promise I won't be impounded and I am not worried about being DQ'd for not having it since it is my first race in the car and the field should be quick and I am just planning on getting in and having a clean and fun run on my maiden voyage
    Johhny Reisert
    Great Falls, VA
    Post
    The fuel port regulation has been established long enough that any decent tech inspector should easily notice that you do/do not have one installed. At this point, I doubt that they would allow you to race unless one is installed.
    You could always ask for one-race dispensation, but why risk it?
    Larry Oliver
    International Racing Products
    Larry Oliver
    Liked: 3795
    Post
    I use one of Paul Morrison's ports between the cell and the pump. I blow into the vent line to force fuel out when the port is opened.
    Paul Morrison's Fuel Ports
    I would connect yours between the cell and the pump as I do with Morrison's.
    Liked: 572
    Post
    On my car (not an FF2000 but similar), the fuel port (also from Paul Morrison, super nice guy) is installed after the fuel pump. It's handy there because I can use the fuel pump to pump the gas out.
    I ran a new braided fuel line from my regulator to the rear of the car so that I do not need to remove body work to get to the port. It's a heavier set up than I'd like, but I like the convenience. I keep the loose fitting (the adapter needed to get fuel out of the port) in my race car in case it's needed at the end of a race or session. It is in the cockpit in an out of the way spot held in place with some velco straps.
    Somewhat related - I know a racer who always has a dime in his racing suit's pocket in case he needs to undo a Dzus fastener. Probably a good idea to keep the dime right next to the $50 bill to be used for bribery if necessary.
