Results 1 to 31 of 31
Thread: It's finally in
    Classifieds Super License Skelly's Avatar
    Clovis, California
    Liked: 82
    Default It's finally in
    After many months behind schedule i have finally installed my Honda fit into my 99 VD. Hoping to have the water lines and oil lines done by the end of the year. If anything does not look right to my fellow racers please let me know before i go to far. thank you all who have helped with the water line problem i had. Will update as i go along.
    Sean
    Denver
    Damn. That's clean. And a tight fit (no pun intended).
    What'd you do with the Ford engine? :-)
    -Mike
    Mike Green
    Piper DF2 FF
    Liked: 555
    Sean, what was the problem? HPD sent you a bolt-on kit. Should've only taken a weekend. :-).
    Just joking, of course. It looks great and I know you're going to enjoy it.
    Clovis, California
    Liked: 82
    Default Pinto
    Hey Mike
    Sold the pinto to a S2 driver That was lookign for a good spare engine. Sold it for a liitle these then i planned, but it was taking up to much space in the garage.
    Hey Russ
    The engine and gearbox went together perfectly. I am very anal about having my wiring, and all parts perfect so i have less problems later on. The Hpd kit is great, but could use a little more work on the instruction manuel. Will send more pics as it goes.
    Sean
    Liked: 4363
    Congratulations! It only gets better
    Clovis, California
    Liked: 82
    Default new parts
    I will also be adding an airbox type system for the engine. The guys at HPD said that it would be a good idea if i could make it work.. I am also having rick at aerocraft make a 1 peice engine cover instead of having to glass the supplied unit. He will also make a mold for future VD honda kits for people. . Will send out pics of the airbox and future work soon.
    Sean
    SoCal
    Liked: 102
    A thoroughly sealed cold air intake duct is definitely worthwhile:
    http://thinkfastengineering.com/2012...ling-coolness/
    Vacaville , California
    Liked: 77
    looking good Sean
    JR
    Linden, Ca
    Liked: 25
    Default Nicely Done!
    I'll have to stop in and check it out in person on one of my trips to Raisin town. So you have a target track day?
    Chuck
    Senior Member Beartrax's Avatar
    Liked: 96
    That's what she said!
    (sorry)
    Looks great.
    Barry Wilcock
    Contributing Member Mike Scanlan's Avatar
    New York
    Liked: 94
    Default Protect harness to crank sensor
    Looks great, but you should make a heat shield running down to the crank sensor. Heat is the enemy for the Fit harness. Here's a shot of what I did, your exhaust probably runs down and out so protect the sensor. Either way it gets hot on that side. Good luck.
    Clovis, California
    Liked: 82
    Default heat shield
    Thanks Mike
    I will put that on my list of things to do. I was also thinking of heat shielding the oil line from the tank to the engine because the exhaust goes right along next to it. Thanks everyone for all your help. Will keep sending in more pics.
    Sean
    Clovis, California
    Liked: 82
    Default updated install pics
    slowly getting the engine install finished. throttle, oil cooler, fuel lines, tank to engine oil line are all finished. The exhaust, fuel vent, cold intake are next. pics added.
    Sean
    Clovis, California
    Liked: 82
    Default Almost done
    Slowly getting this kit done. If anyone has an input to make this look better please let me know.
    Sean
    Liked: 555
    It looks great. Are you near 'start up'?
    Clovis, California
    Liked: 82
    Still need to install the ECU and wiring harness, fit airbox, exhaust and brackets. Still much to do. I get more motivated every time a get a new part on..
    Liked: 555
    Quote Originally Posted by Skelly View Post
    Finish the plumbing, fill it with fluids, plug in the ECU and harness temporarily, forget the airbox and brackets and fire it up.
    There I just saved you a lot of time and you get the reward of hearing your creation run much sooner. You're welcome. :-).
    Clovis, California
    Liked: 82
    Thanks Russ
    That would be a great idea. Hearing the engine running would bring a big smile to my face.. I am only a few months behind getting this completed so this would keep me motivated..
    Sean
    Durham, NC
    Looks good Sean!
    Ray
    Clovis, California
    Liked: 82
    Thanks Ray
    Are you already to go racing?? I did some changes on my fuel system because i am going to use the optional kit with fuel pressure so i tapped another 1/8 npt into the supplied fittings so i could install the fuel test port on the same piece.
    Sean
    Durham, NC
    Thanks Ray
    Sean
    Nope, not ready yet. I'm in the process of repairing my car from my bad weekend at Watkin's Glen in October. My car is a bare frame right now although all the wiring is still in it. I should have a new belly pan on it this weekend and then I can start putting everything back together. I won't race until April so I have some time.
    Ray
    Marietta,Ga.
    Liked: 61
    Thanks Russ
    Sean
    I always fire one up to test the wiring & oil pressure before I hook up all the water hoses also, don't need no stinking cooling to just run a minute or two.
    Scott Woodruff
    (former) F440/F5/FF/FC/FA
    Clovis, California
    Liked: 82
    Finished installing the exhaust, heat sheilding crank trigger wire, and have airbox almost done. Hope to start on the wiring harness next weekend.
    Sean
    Clovis, California
    Liked: 82
    Default Honda Fit update..
    Sean[/QUOTE]
    Contributing Member jimh3063's Avatar
    Easton, Massachusetts
    Default Nice
    Nice work. As the brits would say, tidy!!
    Jimmy Hanrahan
    jimh3063@yahoo.com
    Clovis, California
    Liked: 82
    I am half english, and tidy is a word i have been using more and more getting this car done.. Hope to start on the wiring harness next weekend. Will post more pics as i go along.
    Sean
  27. #27
    Linden, Ca
    Liked: 25
    Darn it Sean, I just looked at your pictures. I dropped my roll bar off at the powder-coaters yesterday and guess what color it's going to be! Team colors?
  28. #28
    Mn
    Liked: 202
    Very nice work ! Very tidy, indeed !
  29. #29
    Clovis, California
    Liked: 82
    Thanks. Just trying to do it right the first time. Hate going to the track to and work on the car. The airbox is taking some time, but will force a lot of air into the engine. HPD said that it would help.. Chuck- send me pics of your car. I have always ran the red/yellow/ black combo on my winged cars..
    Sean
  30. #30
    Monterey, CA
    Liked: 22
    [QUOTE=Skelly;379804] The airbox is taking some time, but will force a lot of air into the engine. HPD said that it would help..
    Looks good, Sean. I'm sure HPD knows better than anyone if there's a benefit to ramming air to and thru a 30.5mm hole, but I have my doubts! Regardless, I like the way your airbox is looking, but make sure the air filter inside it (assume there's one in there?) does what the rule says so's you avoid any potential protest/penalty box issues. Not that it's ever happened in SFR....
    from the GCR... "The upper manifold, air box and throttle body assembly must be used as delivered from HPD. External throttle return springs are unrestricted.
    a. Air filters are unrestricted. All air entering the engine must pass through the air filter prior to entering the throttle body. No devices such as, but not limited to, air horn(s), trumpet(s), bell mouth(s), velocity stack(s), vortex generators and or turning vanes are permitted inside the air filter or between the air filter and the throttle body. "
    See you at the track, and good luck with getting it finished!
    DZ
  31. #31
    Clovis, California
    Liked: 82
    Hi Dave
    This filter has a cone shaped element inside like the z-tech FC engines have. It does not have a trumpet, or velocity stack in it. I did read over the rules a lot before i bought it. I just wanted to make sure the engine got as much air as it needed. Thanks for watching out for me.
    Sean
