Results 1 to 8 of 8
    Huntsville, AL
    Liked: 57
    Default Compression Gauge
    I'm looking for a compression gauge for GSXR motor. Any suggestions?
    George Bugg
    NovaKar
    F600
    Liked: 1507
    get a leak down tester instead
    atlanta, ga
    Liked: 136
    You'll need special adapters that do not come with an automotive type, universal kit.
    Might want to see what's on the Snap On truck. Pegasus?
    Just need to borrow one? I hear bike mechanics can be befriended quite easilly with a 6 pack...
    Huntsville, AL
    Liked: 57
    Thanks. Looks like there's a few choices out there with the 10mm adapter that I need - everything from $55 to $300. While I'm not a "tool snob", I don't want a one-time-use gauge, either.
    I'll look around for a local 6-pack-bike-mechanic! Good idea, Mr. Coop!!
    George Bugg
    NovaKar
    F600
    Royal Oak, MI
    Liked: 290
    I already had on-hand a leakdown and compression tester (from Longacre)... I was able to get just the necessary size spark plug hose from one of the online bike supply houses, think it was BikeBandit.com...
    Vaughan Scott
    #77 ITB/HP Porsche 924
    #25 Hidari Firefly P2
    http://www.vaughanscott.com
    VA
    There is a motorcycle specific Snap-on kit.
    New market, AL
    Default local guage
    George,
    I have a snap-on compression guage set for regular automotive use. If you can get an adapter you can use it all you want. It may be possible to make an adapter for it using a spark plug. If your interested give me a call. 256-682-7849.
    Jerry
    Huntsville, AL
    Liked: 57
    Thanks Jerry! I found one one ebay with the 10mm adapter, but I appreciate the offer.
    George Bugg
    NovaKar
    F600
