Results 1 to 25 of 25
    Wisconsin
    Default WTB: 8" and 10" Wheels
    I'm looking for some 8" and 10" wheels for spares. E-mail me @ ggreenfield@bergstromauto.com
    Liked: 3793
    Might want to mention what hub they need to fit on.
    Senior Member GAR's Avatar
    Long Island New York
    Liked: 53
    I have a set for F2000 cars if that works for you
    Group-A Racing
    Blue Marble Cocktails Radical Cup & Exclusive North East Radical Sports Car Dealer
    (631) 974-4379
    www.GroupARacingTeam.com
    Wisconsin
    To be honest, I dont know the size. Its for a Speads F1000 if that helps. I'm new to the series and to these cars so im not sure what hub size it is (didnt know there different sizes for these cars)
    Liked: 3793
    Did you call Bob yet? He knows everything about Speads.
    Bob Schader
    1129 Chestnut Ave
    Longmont, CO 80503
    E-Mail: rkschader@gmail.com
    Phone: (303) 516-9217
    F1000champ
    Guest
    You can also check with Richard Cottrill at Rilltech-Speads at 303-776-8855
    Somerset, Kentucky
    Liked: 126
    You can also simply take some measurements.
    Wisconsin
    I'd love to but dont know what to measure. When looking at some wheels in the classifeds they talk about 3 measurements: Center, Drive Pin Diameter, and drive pin circle. Where are these taken? Thanks again for all the help.
    Example: These are the wheels i'd like but not sure if they fit.
    http://www.apexspeed.com/forums/showthread.php?t=46418
    F1000champ
    Guest
    Contact Richard Cottrill at Rilltech-Speads 303-776-8855, he should be able to give you the measurments. I think the wheels you're looking at on ApexSpeed have been sold by the post.
    Wisconsin
    The wheels have been relisted by a different seller.
    F1000champ
    Guest
    I'll contact Richard for you and see if I can get you the dimensions for the 2003 Speads wheels.
    Wisconsin
    The center hole is 2.25" so I would assume my hub size is 2.25" .... 17/32" drive pin hole and a 3.5" drive pin circle diameter.
    Somerset, Kentucky
    Liked: 126
    Van Diemen pattern. Makes it easier. Watch for brake caliper clearance (measure) before you purchase. The relatively cheap aluminum Van Diemen OZ's in 8's and 10's will most likely work.
    Tulsa,Ok
    Liked: 60
    Default Drive Pin circle Diameter
    Isn't the VD drive Pin Circle Diameter 3.75"? He is saying his is 3.50"
    I believe the Swift pattern is 3.75 also.
    Somerset, Kentucky
    Liked: 126
    Mike - you are absolutely correct! I blew right over that part. Nice catch.
    Wisconsin
    Quote Originally Posted by Mike Holland View Post
    I could have measured wrong ... is the drive pin circle measured form the center of a drive pin hole to center of the drive pin hole directly a crossed from it?
    Tulsa,Ok
    Liked: 60
    Default Drive Pin Circle
    Yes Center to Center of two pins directly across each other. You can measure outside of one pin to inside of the other pin.
    Wisconsin
    Thanks ... I will double check this weekend.
    Washington
    Liked: 26
    Is anyone running 8" and 10" wheels?
    Wisconsin
    The other FB's running here (Blackhawk Farms raceway) all run 8's and 10's
    Tulsa,Ok
    Liked: 60
    Default 8 &10 wheels
    Coop has a set of 8 & 10 wheels for sale that are for a RFR. They have rains on them.
    http://www.apexspeed.com/forums/show...499#post337499
    Liked: 726
    Quote Originally Posted by openwheeler37 View Post
    Who?
    Wisconsin
    Who?
    I know both the Mazzio's (Ruddy and Gino) are.
    Wisconsin
    Thanks!
    Member TimWalsh's Avatar
    Bloomington MN
    Liked: 6
    For Sale 8 & 10 New VD rims
    I have one set of brand new never had tires mounted on them.
    Tim Walsh
