Page 2 of 2 FirstFirst 12
Results 41 to 45 of 45
Thread: New for 2012
  1. #41
    Tulsa,Ok
    Liked: 60
    Default Bargeboard
    It is only stating that bodywork can only have a gap if it is necessary for engine cooling not if the body work is necessary at all.
  2. #42
    Liked: 1891
    You are misreading what I wrote.
    The gap created by the bargeboard ( and therefore the bargeboard itself since it is what is creating the gap) has to be shown as necessary for engine cooling to be considered legal.
  3. #43
    Romeo, Michigan
    Default Gap
    http://www.youtube.com/watch?v=f1oMhMwUbgc
    1:45 Gaps are properly defined - see you later I'm off to play the grand piano.
  4. #44
    Liked: 1891
    I'm back after taking my pet bee for a walk........
  5. #45
    Indianapolis, Indiana
    Default or shock, or brake cooling!
    Yeah, that barge board is designed in such a way that -- in swirling and turbulent air created by preceeding cars -- causes a cork-screwing highly excited stream of air to cross over the top of the car's shock covers (which are located directly over the dampers, of course) this leading to a .0001 F decrease in the damper's oil temperature. Therefore those barge-board thoroughly and completely in compliance with the 2012 GCR!
    Right?
    Chris
