Page 6 of 12 FirstFirst ... 2345678910 ... LastLast
Results 201 to 240 of 465
Thread: 40 LBS
  1. #201
    ASRF1000
    Guest
    Which closed loop system is Jeremy Hill using @ 2:07.0?
    Josh, if I'm correct (and I could very well be wrong) I believe Jeremy Hill is running a fully mechanical shifter.
  2. #202
    VA
    Impossible.
  3. #203
    ASRF1000
    Guest
    OK. I'll rephrase/clarify. There's no doubt in my mind there is a performance advantage. You'd have a hard time convincing me that everyone who is at the Runoffs with one of those systems did not add it because they thought it would either decrease lap times or increase their competitiveness in some way.
    For instance, weren't people saying they could not downshift fast enough manually because of the short braking distances?
    And, if assisted shifting makes driving easier, doesn't that free up your mind and muscles for other things?
    I'm not in the FB class, so my opinion isn't pertinent. However, I think expensive shifter systems make the class less attractive to people considering the class. Well, let me back track. I'm sure there are some people out there who wouldn't mind that extra cost and want wizzy technical goodies.
    Exactly my point Russ. The advantage comes from the driver's ability. Not by mechanical advantage (ie: lower weight, more HP, lighter brakes, etc.). It's a driver's aid and there are drivers whom are good enough that don't need one. All this does is make it easier for those who can't and what's wrong with having more drivers running at the pointy end of the grid? Like I said, right now its a free choice and the choice is trying to be taken away.
  4. #204
    ASRF1000
    Guest
    Impossible.
    At the very most he may have a no-lift shift, but does not have a full closed loop system, and he qualified 2nd.
    The Piper also has at the most a no-lift shift and no closed loop system and they qualified 3rd.
  5. #205
    VA
    Pretty sure Hill has just a mechanical shifter.
  6. #206
    ASRF1000
    Guest
    I believe so as well, but I'm checking on it.
  7. #207
    Coral Springs, florida
    Liked: 84
    Quote Originally Posted by ASRF1000 View Post
    Gene Simmons???? Gee John, you could have at least chose someone who looks better....LOL
    thats a compliment, I'm not talk about looks, he's the #1 rockstar business man marketing guru in the industry. He's got KISS underwear....don't get any ideas for F1000 championship offical underwear!
  8. #208
    ASRF1000
    Guest
    Well, thank you John. But, you mean I have to tell Hanes and Michael Jordan the deal is off?....LOL
  9. #209
    atlanta, ga
    Liked: 136
    Jeremy has a Novak Paddle Shift with a Dan Robinson (DR) Blipper.
    The first two rows of the grid looks like this (to my knowledge):
    Geartronics
    No wire
    Flat Shifta
    Geartronics
    Oh yeah - FTCRB!
  10. #210
    VA
    FTCRB!
    Agree 100%. Free the CRB from their oppression here on Apexspeed!
  11. #211
    Huntsville, AL
    Agreed, but you have to admit that they have done a pretty reasonable job already of freeing themselves from the oppression of member input. It sure doesn't seem to have any bearing on the decisions they make.
  12. #212
    Marquette, Mi.
    Liked: 43
    Mr. Lewis
    The fact is that strapping another 40 lbs to a 1,000 lb car with only 170 hp is like tying an anchor to it.
    Please quantify in (time/seconds) what you think this weight or "anchor" will do to an average lap time compared to no anchor. What is your educated guess on let's say a two mile track?
  13. #213
    Liked: 84
    http://autopedia.com/stuttgart-west/...Physics06.html
    don't ask me what any of it means.......what I do know is in Motorcycle racing you are giving up alot being 40lbs heavier, these little F'ers go by you like you standing still.
  14. #214
    ASRF1000
    Guest
    Mr. Lewis
    Mr. Robinson,
    I cannot quantify (nor would I attempt to GUESS) in time/seconds exactly what an extra 40 lbs would do without actually testing it back to back. But, what I can say with relative certainty that 40 lbs will slow a car down significantly to one that is 40 lbs less.
    Just look at what 40 lbs does to a car in World Challenge and were talking 3,000 lb cars with a lot more horsepower.
    My point is that 40 extra lbs does a lot more to the performance of a car than an assisted shifter system. Just look at the winner of the Runoffs. A mechanical shifter with a flatshift. So where's the performance advantage of a shifter system?
    Can you quantify or have an educated guess of what the difference in time/seconds would be for a car with and without an assisted shifter system? Of course not. Again, my point. The 40 lb penalty has been recommended by the CRB without any basis or fact. The only way you should impose a penalty is only after adequate testing.
    1. use the same car and driver on the same track and same day
    2. Have a second car as a baseline for changing track conditions, tires, etc. (the configuration of this car stays the same throughout the day)
    3. use a driver that is very good with a mechanical shifter
    4. run the car with full mechanical
    5. run the car with a shifter system
    6. Determine the lap time difference (if any)
    7. IF the car is faster with a shifter system, slowly add weight till the times equal out.
    8. This would be the weight imposed for all cars using a shifter system
    This is the only way you can justify a weight assessment. Any other way would be simply guessing without any basis.
    Of course this would mean that they would have to spend time and money to determine what the real outcome should be. And, you have to take into consideration what systems are being used. Is it a simple system like flatshift or a more elaborate system like Pro-Shift or Geartronics and are there different weight assessments for different systems?
    Right now, it is the option of the driver/team as to whether they want to use an assisted shifter system or not. It's not a MUST HAVE situation. Leave it alone until you have quantifiable proof of any performance value.
    F1000 was formed on the basis of innovation. That's one reason why it is not spec. It was also based on a low cost formula. Low cost is a relative term. Even with a shifter system, the class is still low cost. Low cost doesn't mean the cheapest. Costs are kept down by having tube frame chassis, no carbon fiber, stock engines, no carbon brakes, etc.
    Shifter systems like the Pro-Shift and Geartonics (although the initial cost is just under $5G) can help save money in the long run in engine and gearbox maintenance, etc.
  15. #215
    Liked: 1891
    Default Accelleration
    A simple 1/4 mile acceleration calculation ( with the only difference being the extra weight) will give you a .13 second difference just for that one acceleration run.
  16. #216
    Marquette, Mi.
    Liked: 43
    Thank you Richard.
    Jon,
    Your statement is exactly why I originally started this thread. It was to bring out some substance and how the 40 lbs would affect these cars. It was also meant to bring to dicussion just how detrimental this level of weight penalty would be to these cars. We now have an example of how the weights affects the linear acceleration of a car and I would bet that cornering performance would be greatly affected also.
  17. #217
    Contributing Member tstarke4's Avatar
    Rockville, Virginia
    The Geartronics systems carries it's own weight penalty as it it is significantly heavier than the mechanical system it replaced.
  18. #218
    Liked: 1891
    Default No pat answer is possible.
    Weight differences will impose varying time difference results depending on the track, so it is impossible to give a one-size-fits-all answer. If someone out there has one of the better simulation programs, it would be interesting to see what the difference would be between, say, Gratten, Mid Ohio, and RA.
  19. #219
    Chatham Center, New York
    Liked: 865
    To put the weight penalty in a real world context: In a back to back test (one VD FC car using fuel as the weight change) 25lbs was approx .4 sec/lap at Summit Pt a few years ago. Kevin F can verify and fill in details.
  20. #220
    ASRF1000
    Guest
    Bob,
    So using your calculations, a 40 lb weight difference would cause over a half second per lap. Times that by let's say 18 laps and you come up with over 9 seconds. I would say that is a pretty significant penalty.
    Richard, you are correct that each track presents its own challenges and parameters on how weight can affect the performance of a car. There is no one size fits all situation you can come up with here.
    I just wish the CRB would leave this class alone and let it grow. At least we don't have to worry about all this in the new Series. It would just be nice if the club also saw it the same way.
  21. #221
    Huntsville, AL
    Brandon and I discussed trying to do back-to-back testing on what 40 pounds would mean for lap times at the ARRC, but we have no idea where we would be able to put the 40 pounds on his car. We are already using tungsten for ballast.
  22. #222
    Liked: 14
    Bob is very close with his numbers. We tested 25lbs (25.6 to be exact) at Summit Point which is a 2 mile track with high and low speed turns and straights.( best test track I have ever used) The difference was .3 seconds per lap. Now mind you we were using fuel and not ideally placed ballast but it made the point for what we were trying to accomplish. The CRB then chose to use a heavier untested weight but thats another story and I really am trying to keep my blood pressure down these days. The test was done with a FC car that at the time was making apx 144 hp in the spec we did the weight test at.
    Kevin Firlein Autosport,Inc.
  23. #223
    Marquette, Mi.
    Liked: 43
    Wren,
    Considering using lead shot from an ammunition store and package it in small cloth bags wire tied to the various nooks and crannys available in the car. The bags of shot are formable and will contour for fitment.
  24. #224
    VA
    One ballast method I saw was making a bead seat and using lead shot in place of some of the beads in the lower portions.
  25. #225
    ASRF1000
    Guest
    I think Wren's point is, adding another 40 lbs to their car to compensate for a shifter system would be very difficult, at best.
    I'd hate to have little beads of shot sliding around in the cockpit if any came loose. Also wouldn't like the thought of 40 lbs of lead strapped to my ass.
  26. #226
    Huntsville, AL
    40 pounds is a lot of lead shot or bags, which is already less dense than the tungsten we have now. I had to put 25 pounds in my DB-6 to make weight and that car has more nooks and cranny's than Brandon's car and it was still a challenge. Brandon's bodywork is tight to the frame, unlike the DB-6. No way he is cutting up his new bead seat to perform a test to verify that the CRB is FOS, which everyone already knows.
    We were mostly interested in taking some data and sharing it with the CRB, although they were not interested in the original data Brandon offered them. I guess decisions are easier in a vacuum.
  27. #227
    VA
    I didn't think you should cut apart the bead seat. I just thought it was a clever way to find one more spot to cram a few pounds of lead for someone who was scratching his head to find where to fit all the necessary ballast.
  28. #228
    A modern simulation program such as ChassisSim, Aerolap, etc. should be able to provide some pretty accurate numbers regarding the effects of 40 lbs. upon lap times. The problem is that I am not aware of any current FB race team that has the time and resources to do this properly. The software is very expensive, and it of course takes time to learn and master. You also need to have the information at hand to completely model your car in the software......for example: geometry, weights, cg, damping, aero map, hp curves, tire model, etc.
  29. #229
    Quote Originally Posted by Rick Ross View Post
    Or you could just use Steve Matchett's rule of thumb that 10 lbs is worth a tenth of a second per lap.
    How much faster does that leave Brandon?
    Huntsville, AL
    A lot. And it doesn't mean **** if it keeps raining.
  31. #231
    ^^^Word^^^
    Liked: 14
    Stan the problem with Steves estimate is he has been around F1 fpr too long. F1 also says it takes a Million $ to get a second a lap. Then again think of all the $$$$ that means Lee has to spend with you to drop that .9 from his 2:00 lap
  33. #233
    Shhh...don't tell him!
    TORONTO
    Liked: 80
    If anyone truly believed that a front-running FB could be built for less than $20K, I've got a bridge in Brooklyn that I'd love to sell to you. 30-40K, yes, IF you have found a cheap donor car and can do all of the machine and fab work yourself.
    as a matter of fact i built my car for less than $20k (not including labour) my shifter is fully mechanical, perhaps with a geartronics shifter i would have been on the pole...regards, jeremy hill
  35. #235
    NJ
    Quote Originally Posted by JEREMY HILL View Post
    Good job on the car.
    I was just googling you name, did you run Can-Am back in the day?
  36. #236
    TORONTO
    Liked: 80
    yes, i ran under 2L can-am 83 through 86, jeremy
  37. #237
    Huntsville, AL
    When does the BOD meet for this?
    Jeremy, do you mind sharing how much you weighed at the end of the race? The geartronics might have put you in third too. You never know.
  38. #238
    The BOD will vote on this at the October meeting. This is in about 3 weeks.
    Thanks ... Jay
  39. #239
    TORONTO
    Liked: 80
    i am happy to share, my car was 1004 lbs after q4, lets be serious if geartronics was not an advantage no one would be using it, perhaps all you guys running the geartronics can tell us honestly how much of an advantage it is, my quess is that at road america with a good driver it is worth at least .6 sec and i believe that a 40 lb penalty would be a .4 sec disadvantage, jeremy
  40. #240
    I think that is an extremely reasonable statement Jeremy.
    My major concern with the entire issue is that I think it is extremely important that both the Pro series and the National series have exactly the same rules. If not then neither series will survive over the long haul.
    I made my position known at the CRB town meeting at the Runoffs that I supported assisted shifting systems. However I will abide by what ever decision the BOD makes on this issue.
