Hi Peter and everyone,
I'm VERY glad you figured it out! I must give you credit for being persistant![]()
But that's odd that you had your options.cfg in the run folder, unless you copied it yourself there... Normally, it should be created automatically in the correct folder when you start Heat or any MOD.
At least we know the solution now, thanks Peter.
As for ML2 not giving you the prompt - do you have 'nascar heat.exe' in the main folder or 'nheat.exe' ? Or both? If you do have 'nascar heat.exe' then this is why you don't get the prompt, if you have 'nheat.exe' most likely you will get that prompt, and finally if you have both then most likely you will also get that prompt. ML2 acts differently depending on what you are launching, how you do it and what you have in your folders, thus, v1.4 searched for 'spl_scr' file in a MOD directory which is a custom splash screen, and it showed it if it found it, but I forgot that XP users get that prompt when they launch Heat, when ML2 v1.4 launched a MOD with a new splash screen on XP system, users couldn't press "Yes" to continue, unless they minimized it, so I fixed it and now I can say for sure that you won't get the prompt on XP if the MOD has a 'spl_scr' file in it, if it doesn't then you might get it, it depends on the name of your executable in the main folder.
BUT, I can make so that the prompt didn't appear in any of the cases, I just need to know if it does appear on anybody else's PC ?
So grab v1.4.1 and give it a try:
MOD Launcher 2 v1.4.1
Oleg
