Results 1 to 31 of 31
    Ohio
    Liked: 6
    Default Two 2L Pinto motor
    I have two 2L Pinto motors for sale, both iron heads.
    Motor #1 - Elite motor w/ Quicksilver intake. Recent F2000 motor, 4th fastest in practice on Saturday @ Road Atlanta, finished 7th. New SCCA cam and lightened flywheel, motor complete w/ oil pump system and 5" clutch. Motor has two F2000 weekends on it since top end rebuild and dyno @148hp, believe bottom end has Runoffs and 4 race weekends. $3,900
    Motor #2 - Elite motor, backup motor we purchased used and ran over the winter for 2 race weekends. Complete w/ oil pump system, carb and linkage, clutch & pressure plate. Missing water intake piece and engine mount. I have various engine mounts will send with motor but not sure what they fit. Lightened flywheel, but older cam. $2,500
    Bruce Work
    330-518-1073
    Waterloo, Iowa
    Default 2.0L Engines
    Are engines still for sale?
    Ohio
    Liked: 6
    Default 2l pinto's for sale
    Motors are still for sale. Located in Ohio.
    Bruce
    Ohio
    Liked: 6
    Bump
    Ohio
    Liked: 6
    Motors still for sale
    Ohio
    Liked: 6
    Both engines still for sale.
    Ohio
    Liked: 6
    Bump
    Pittsburgh
    Liked: 296
    Just in case it isn't clear. These two engines are the engines that Work Racing started the 2010 F2000 CS campaign on. The one with the new cam took me to two top ten finishes. Good running!
    San Diego , CA
    Default shipping cost???
    Any idea what the cost would be to ship a motor to the San Diego area??? Weight and size? Crate available?
    Ohio
    Liked: 6
    Default 2L pinto for sale
    I have an engine crate for the $4,500 engine, it is 26" x 23" x 30" my guess is 300 pounds engine & crate. Zip code is 44443.
    Bruce
    Liked: 1504
    my guess is about $450. My last engine to go from SoCal to Portland was $300 each way, picked up and received at a business via UPS freight.
    There's a new advertiser on Apexspeed, would be interesting what his costs might be.
    Destin FL
    Liked: 649
    I just sent my engine from MN to Jay Ivey in OR for $138.
    Rick,
    Which shipping company did you use?
    Ohio
    Liked: 6
    Default Pinto motors for sale
    Bump
    Senior Member Bob Coury's Avatar
    Jupiter, Florida
    Liked: 79
    Bruce:
    Just curious by your ohone #. Are these in Boardman?
    Bob
    Ohio
    Liked: 6
    Close...New Springfield, both engines still available.
    Bruce Work
    Ohio
    Liked: 6
    Price reduced 9/13/2010
    Contributing Member bigbaran23's Avatar
    Bloomfield Hills, Michigan
    Default Flywheel / Cam / $$ reduction
    What flywheel do you have in these engines? The 10-1/2 pound Elite flywheel or a lightened original flywheel - usually 12 1/2 lbs +-? I know you cant get the original flywheels ground and balanced much below 12-1/2 lbs. I am curious because I did run both and I found the 2 lbs did make a difference ...I am interested in one of the two engines. Is the Cam an Ivey purchased cam? What are your reduced prices if I may ask?
    Thank you...Dennis Baran
    Ohio
    Liked: 6
    The flywheels are original, lightened by Elite. The cam was purchased and installed by Elite. Just lowered prices this week.
    Bruce
    Default Fly wheel and $$$
    So I am to assume they are 12 Lbs? Can you share what the reduce prices are? Thank you
    Ohio
    Liked: 6
    I have never weighted them, I don't know where your information on the minimum weight for original vs new came from so I can't speak to how accurate it is. You might call Elite and ask them what they cut original flywheels down to, weight wise, because they did these. The prices are changed in the original post above. Engine 1 reduced form $4500 to $3900, Engine 2 reduced from $3000 to $2500
    Bruce
    Member Proulx's Avatar
    Annapolis, MD
    Default Instructions
    email chefrejean@aol.com and yes I would pick up Wed
    Ray Proulx
    5109 Holly Dr.
    West River Md. 20778
    Cel 443-9947403 Res 410-867-3768
    Ohio
    Liked: 6
    Engine #1 sold, Engine #2 still for sale
    Destin FL
    Liked: 649
    Rick, sorry about the delay. I just missed this one.
    I used Yellow Freight. I'll see if I can find the BOL. Ask for the discount!!
    Senior Member mbrandt1402's Avatar
    Newport, WA
    Late to the party, but the cast iron flywheels are easier to bring down to the minimum than the Ford Motorsport steel flywheels.
    email or pm me for details.
    University Place WA
    Is #2 still for sale?
  27. #27
    Ohio
    Liked: 6
    yes #2 still for sale
  28. #28
    University Place WA
    Quote Originally Posted by bhwork View Post
    Bruce,
    Is #2 still available?
    Steve L
  29. #29
    Ohio
    Liked: 6
    yep, engine #2 is still available
  30. #30
    Default engine #2
    how much $$ for engine number 2?
  31. #31
    Ohio
    Liked: 6
    both engines have been sold
    thanks apexspeed
