Since the FF/FC rules change proposed in the September Fastrack is specifically targeted at our car, I thought I should post some information about the Radon Rn.10 chassis and some photos of the first few cars under construction.
We have spent a lot of time and effort to design a safe and easy to maintain car and we expect it to cost less than a new Elan/Van Diemen (or, I suspect, any other complete car). We've been able to achieve this by a combination of good design and modern manufacturing methods. We also hope it will be competitive on track.
We don't have the time or resources to completely redesign the car to meet such drastically modified rules, so if the proposed rule changes are adopted we won't be involved in SCCA Club Racing.
It is your club, so if you want the car banned, and you think that's in the best interest of FF/FC and the SCCA, then you should let the CRB know. On the other hand, if you think the Rn.10 would be a good thing for Club Racing, let the CRB know that.
The Rn.10 is a tube-frame car, as you can see from the photos. In fact, the roll cage was designed to meet 2009 FIA F3 rollover protection standards, so it is roughly six to ten times stronger than the minimum SCCA requirement.
We have designed and constructed a cockpit safety cell using 4130 steel tubes, a 16 gauge 4130 steel floor, and cockpit side protection panels. The cockpit side panels provide much more protection to the driver than a tube frame alone, and are similar to the panels required in recent FIA safety standards. The panels are made with carbon fiber (woven and unidirectional) and Innegra fiber (a very low cost fiber that has some of the characteristics of Kevlar). Both materials are banned in the proposed rules. The panels are bolted to the tube frame on centers of six inches or more in compliance with the 2010 rules, but would be illegal under the proposed new rules.
Aside from safety, there are other benefits of the panels. Because we can bolt directly through the panels, and because they provide some bracing, we eliminate many of the little tubes and brackets that are present in existing cars, and the end result is a frame assembly that is less expensive.
In the case of a bad accident, the panels can also easily be removed and replaced without requiring costly straightening and weld repairs.
A further safety benefit is that the interior of the cockpit is almost completely smooth, without any protrusions or tubes that can rub against the driver (either during normal driving or in an accident).
We've also done some nice things in other areas of the car, but I'm primarily addressing those areas made illegal by the proposed rules changes. I'd be glad to answer questions.
Regards,
Nathan Ulrich
Technical Director
Radon Sport LLC
