With your listed track values, it looks like you are planning to run 8" front rims, bringing the max width to the max allowed 72" width of the car. Don't forget that the tires stick out a bit past the edge of the rims.
Don't worry, I have not forgot about my current FB endeavors. Assorted tin-top projects have kept me away (wing design and motor rebuild for the Bimmer).
Last weekend, I worked tech at the Queen of Hearts Double National at MSR Houston. During post-race impound both days, I was able look over the RFR F1000 quite closely and pick the brains of David Burkett's crew. Thanks to Scott Hanba from TMG for answering all of my questions!Too bad assorted gearbox gremlins kept them from working on dialing-in the car (and running full races).
My impressions of the RFR-009:
-Astoundingly low to the ground (it was the only car that had clearance issues on the impound scales)
-Quality fit and finish
-Strange body panel breaks
-Not using Dzus fasteners on the panels would make removal difficult
-Front wing upper elements looked weak (could see fibers on one already)
-Rear Sway Bar adjuster cable obscures part of the rain light
-(Per Scott) Very thin body panels (thinner than the Stohr)
-Chunky muffler hanging out
-The Dzus fasteners on the helmet surround are a royal pain to get off (took the surround off for Burkett in impound) (see photo)
Overall, I thought that the car looked great, and I can't wait to take them on next season. Much has to happen between now and then!
I am getting back to the computer tomorrow full of inspiration. Hope y'all enjoy the photos.
David A. McMahon, P.E.
McMahon Raceworks FB/FA/F??? mothballed for now
Looks like they were not running the chimneys - comments? Thanks, Clark
add additional cooling via improved extraction, but only needed for hot weather running.
GC
Over the last few months, I have had to shelve my FB project for plenty of reasons. Keeping an Alfa Romeo running and fixing an M3 for One Lap of America (coming out of 9 at Hallett)...overcoming a hand injury and round two of swine flu...last but not least, moving to Atlanta for the summer to work. I have access to SolidWorks at work and will work on the car in spare moments with the goal of having the design done by August.
I realized that I jumped into this project months ago without taking a moment to define what I am aiming for in this design.
Problem Statement: Design and construct a competitive (maybe not initially) F1000 car in compliance with the 2010 SCCA GCR.
Criteria for Design:
Weight: less than 775lbs
Dimensions from GCR requirements (WB = 1.618*W)
Standard motor mount points with adaptors for various engines (GSXR first)
Radial-mount calipers
Center-lock rims
Provisions for open or LSD
Fit all driver sizes <6'6" <275# with proper angle for HANS device
Work was light today, so I was able work on the suspension design with a simple upright. Based on rough calculations, each arm should be around 20-21" in length. The design uses 1"x.120"wall tube and 1/2" rod ends sleeved down to 3/8". Right now, the assembly is too constrained to test the motion. I am going to go through and remove all of the unnecessary ones and test the motion of the assembly.
I know this iteration may just be an exercise to hone your modeling skills but may I offer some critique.
1) DO NOT use rodends for the UPPER OUTBOARD Joint. You'll want to fashion a way to use a mounting block with SHIMS and use a spherical bearing. If you use a rodend like this you won't be able to make camber changes without changing toe.
2) Lower ball joint...make sure bolt is in DBL SHEAR and use as large a spherical bearing as possible.
I have other suggestions but I don't want to fill up this page.
Regards
Gary Hickman
Edge FB #76
Have you guys read Tony Pashley's book "How to Build Motorcycle-engined Racing Cars"?
http://www.amazon.com/Build-Motorcyc...5010971&sr=8-1
It offers a general approach to designing and building an FB-type car, rather than an overly technical engineering analysis.
The guy had made several bike-powered cars including one made with an alu honeycomb monocoque so he has a lot of practical experience.
I must say it is way over my capabilities, as running and learning how to drive my Stohr F1000 is about all I can handle, but the book helped me understand and appreciate some of the parameters involved in making an FB car.
Ivin
I will add a few items to consider along with what Gary posted.
1. Have the inboard rod ends aligned with the thrust loads. To make the brackets simple you can use the rod ends with a vertical or horizontal bolt.
2. I cheat and use rodends for the top ball joint but I also use shims to adjust camber without changing toe settings. This allows me to accommodate radial and bias ply tires as well as change KPI.
3. I gave up trying to have the lower ball joint in double shear. I use 5/8 spherical bearings for the lower ball joints. This has proven to give very good service. You can use a 7/16 or 1/2 inch stud with bearing inserts.
Your next step will be to figure out what you want for suspension and steering geometry.
Currently, I am using parallel a-arms for this first few iterations and will move on from there as I perfect the geometry.
I have put thought into how to adjust the rod ends without changing toe. If you change the length on both the upper and lower control arms (to change camber) around the axis that the steering is on, the toe should not change. See low quality illustration. Is this reasonable?
On a side note, I own Tony Pashley's book. It has been a good resource, but it is less technical than I expected.
Interesting thought on camber adjustment. But you now run the risk of changing the motion ratio as you adjust camber.
You also need to consider the time that it takes to make any adjustment. Being able to change 4 springs and adjust ride height in less than 4 minutes will give a big competitive advantage on a race weekend.
That is one thing that I have learned so far: there are always trade-offs in design. It certain is a big challenge to design independent adjustability of the alignment (camber, castor, motion ratio...) into the suspension.
Ease of use can be lost when designing digitally. For example, I can change the camber in a few clicks. Less easy IRL.
as you have shown, changing top and bottom arm lengths will not change the toe, but it will totaly screw up your bump steer. i believe that toe is easy to adjust at the track, but bump steer is a lot more work. my .02.
john f
I know this is an older thread, but it applies to a thought I had lingering in my brain from another thread... (sorry for hijacking)
Before I ask, please note that I am a former stock car team guy (non-professional) looking to get into open wheels...
My question is this... In a car that has fully independent suspension, particularly in the rear, is there a way to overcome/eliminate/minimize the effects of adding positive camber as the suspension travels? Or do you just compensate with the static camber setting? (This is how we always did it with "stock" cars, because our hands were tied and we couldn't really try to re-invent anything) Not sure if it is possible to eliminate this effect. Please enlighten me!
You can make the camber curve (camber angle vs suspension travel) change based on your particular suspension geometry (it's a simple 4 bar linkage in 2D, more complicated in 3D when you throw in the toe/steering link). There are two typical camber curves that people look at, deg/g which is camber change in chassis roll (ie cornering), and deg per distance of suspension travel (bump). If you "optimize" one, you typically screw up the other. It ends up being a compromise between the two.
The other big thing to look at is minimizing compliance in the suspension. You want the suspension travel to come from the shocks, not from flexing in the various components and brackets that make up the suspension system.
Billy Wight
Luxon Engineering
www.luxonengineering.com
858.699.5313 (mobile)
billy@luxonengineering.com
Awesome reply, thanks. That explains it quite well.
It is pretty easy, at least in my opinion, to create a geometry with small comprimise between ride camber(straight up and down) and camber compensation (in roll).
Just look at where your instant center moves during roll and you'll start to notice a trend.
But then you have to look out for kinematic roll center migration.
Wright is right...Wright is correct...a compromise indeed. The decision is easier if you know what your tire wants...
Ill add some advice for the OP...
Regarding your kinematics/moving in Solidworks, its really easy if your suspension is derived from a sketch instead of parts. That way you can visualize the motion without worrying about mates. Then when your kinematics are finalized, flesh-out the components and check clearances.
or you could fork out the dough for a kinematics program like WinGeo or OptimumK. Get in touch with either local A-mod guys or an FSAE team if your uni doesnt have one and get some advice.
SolidWorks has this concept called blocks that makes linkage design easy. You take a sketch, that can be as simple as a line, and click tools>blocks>make. You would do this again for each control arm and the upright, then define mates between the appropriate points. When you're done, you can just click and drag a point on the suspension to watch it work. Click Help>SolidWorks Tutorial>Special Types of Models>Blocks for a better explanation.
Coming soon on my agenda is to get this to show me the instant centers and the roll center.
-Jim
Last week, I sketched up a concept for the bodywork. Here is the silhouette of the body inserted into my suspension design file. More updates to come in the next week or so.
Jim...thanks for the SW tip, if you get it to tell you roll and instance center would you mind sharing that with us SW users?
David....profile looks great! Keep the progress moving. If you need any machining done let me know. I also have a knowledge base of UPRIGHT and UPRIGHT INTERNALS going all the way back to the original Swfit D1. The upright internals I used came from my past work on the DB6 so I used all DB6 internals....I also have all the drawings for several iterations of VD upright internals going back a few decades to present.
Also if you need 3 pc. wheels we soon will be offering them for sale. We will have a special deal on first orders.
Regards
Gary @ Edge Engineering Inc.
SoCal CNC
If I were doing a clean sheet F1000 design I cannot imagine wanting to do an overhead air intake. Other than presenting a lot more frontal area and keeping air off of the rear wing, what advantage does it give you?
The stock airboxes on these cars are begging for a better solution. I think Jeremy hill and schweitz are much closer than everyone else.
I completely agree. I think the benefit of reduced frontal area and clean air to the wings far outweigh any benefit of slightly cooler and slightly higher air pressure to the engine. It wouldn't take too much to chech with an existing car either, just a different engine cover and some track time could tell which direction to pursue.
Billy Wight
Luxon Engineering
We have tested both, and I like the ram air box.
Whether you are a CFD expert or not, push the guys running your analysis to justify the way they've done it, particularly meshing. The use of expensive software or hardware does not automatically lead to its proper use, and even getting experienced people isn't enough. They may have 10 years of CFD experience simply doing it the wrong way! The big boys routinely publish poorly done CFD. IMO there are a very select few who really know how to do it properly. On top of that they NEED to understand formula car aero as the meshing MUST be tailored to the specific Formula car phenomena that are important and difficult to capture. What is important to an aircraft or a road car can be meaningless to a formula car!!
A basic design simply drawn up by a good aerodynamicist based on aero principles can be less risky than a design that's "optimized" (hate that word!!) with mediocre CFD. If you've found a good formula car aerodynamicist who does proper CFD you're in luck and the aero aspect of the car will be excellent.
I'm not trying to scare or discourage you. In fact I'm actually happy to see someone making the effort; just giving some unsolicited advice from a CFD n00bHopefully it will help make the CFD of more use to you.
Be careful with statements like those; aero works in very mysterious ways, and things aren't always as bad or straightforward as they seem![]()
