Results 1 to 11 of 11
    Rogers Arkansas USA
    For Sale Stohr F1000 chassis 002 for sale
    I purchased this car in December 2008 for track day use. My previous track experience had been limited to a fast street car (Ariel Atom). Though the Atom is fast, I was not really prepared to make this big a jump. It’s a great car, but just too intense for me at this point. I’m selling it, a bit sadder, but wiser as they say.
    From the beginning I set the rev limiter in the Mychron about 800 below the redline for the 2005 GSXR engine. Plenty of power for my non-racing aspirations and the engine remains in great shape through the twelve track days the car saw in 2009. Since my purchase I have added the C/F floor that bridges the steering rack. This significantly improves driver comfort since the rack is right where my calves want to be. When purchased, the car had a push-pull paddle shifter and a paddle actuated clutch. I replaced that setup with the more typical foot operated hydraulic clutch and double paddle shifter. All components have been purchased directly from Stohr Cars West. I also had the header Jet-Hot coated and applied the gold foil (bulkhead) and engine compartment ventilation measures to the car per Stohr recommendations.
    In addition to the photos, I have some video of the car in action at Hallett - http://vimeo.com/8279144
    Additional items purchased for the car and included in the package are MK Technologies parallel string toe bars, front and rear quick lifts, and Chicken Hawk Racing Digital Pro-Line tire warmers. The tire warmers are complete with custom fitted carrying cases and Pit-Bull stands for the controllers.
    I’m asking $42,500 for everything listed below
    Stohr F1000
    • Powder coated steel tube space frame
    • Super strong, ultra-light fiberglass composite body and wings
    • Full ground effects floor
    • Quaife limited slip differentia encased in CNC-machined “Stohr Spar”
    • Powder coated aero tubing suspension
    • Machined aluminum uprights
    • Wilwood 4 piston front calipers twin piston rear calipers
    • Cockpit adjustable brake bias control
    • Stohr specific machined floating rotors and hats
    • Billet aluminum pedal assemblies, clutch, brake and throttle
    • Stohr F1000 carbon fiber floor panel
    • Steering wheel column mounted billet aluminum paddle shifters
    • Ohlins ST44 double adjustable dampers (compression & rebound)
    • Hyperco springs 700# and 800#
    • Hyperco/ICP hydraulic spring perches (8)
    • BBS 3-piece aluminum wheels - 8.0 x 13 front, 10.0 x 13 rear
    • Goodyear slicks with 1 weekend of use
    • Jet-Hot coated header
    • Stainless steel lightweight muffler
    • Custom aluminum radiator
    • Setrab 45 row oil cooler
    • MOMO suede steering wheel with SPA quick release
    • 6-point safety harness
    • S.P.A, Technique fire suppression system
    • Fuel Safe Inc. fuel cell
    • 2005 Suzuki GSXR 1000 engine prepared by Loyning' s Engine Service
    • Stohr snorkel type airbox with latch system (black e-glass)
    • AIM DaVid video and data logging system with MyChron 3 dash
    • Sensors- Wheel speed, oil temp, oil pressure, water temp, throttle position,
      steering position, lateral G, longitudinal G, beacon transmitter
    • Chase PDR100 digital video recorder with CF card
    • 2 Chase bullet cameras 520 line resolution
    • AutoTel RR710 radio system: mounted Kenwood TK-3140 UHF car radio with
      Li-ion battery and charger, steering wheel PTT, mounted car antenna, Kenwood
      TK-3140 UHF pit radio and headset with Ni-cad battery and charger & carry case
    • Documentation package, log book, etc.
    Spares, accessories and equipment included in sale:
    • Extra BBS wheels: 2 front (8.0 X 13) and 2 rear (10.0 X 13)
    • Stohr transport wheels & tires
    • 2 spare sprocket sets for multiple ratios
    • Spare Hyperco springs 800# and 1,000#
    • Full car set of Wilwood Compound ‘A’ brake pads
    • New replacement forward splitter, side pod skid plates and skid blocks
    • Goodyear rain tires (never mounted)
    • AMB direct wired transponder
    • MyChron optic lap transmitter (beacon)
    • Flatshifter Pro new in box (see www.Flatshifter.com)
    • Stohr Lift bar
    • MK Technologies F1000 parallel string toe bars
    • MK Technologies F1000 front and rear quick lifts
    • Chickenhawk Racing digital pro-line tire warmers with cases
    • PitBull controller stands
    • Misc thermal blanket & insulation items
    Delivery is negotiable.
    Contact:
    Randy Lamp
    479-903-9000
    drlamp@apprenticeis.com
    Contributing Member Tim Webb's Avatar
    Fayetteville, AR
    Default Stohr
    Great car! This car is is extremely clean. Wish I had the funds!
    Tim Webb
    Whitethorn Ca.
    Quote Originally Posted by arielatom View Post
    stohr f1000 chassis 002
    i purchased this car in december 2008 for track day use. My previous track experience had been limited to a fast street car (ariel atom). Though the atom is fast, i was not really prepared to make this big a jump. It’s a great car, but just too intense for me at this point. I’m selling it, a bit sadder, but wiser as they say.
    From the beginning i set the rev limiter in the mychron about 800 below the redline for the 2005 gsxr engine. Plenty of power for my non-racing aspirations and the engine remains in great shape through the twelve track days the car saw in 2009. Since my purchase i have added the c/f floor that bridges the steering rack. This significantly improves driver comfort since the rack is right where my calves want to be. When purchased, the car had a push-pull paddle shifter and a paddle actuated clutch. I replaced that setup with the more typical foot operated hydraulic clutch and double paddle shifter. All components have been purchased directly from stohr cars west. I also had the header jet-hot coated and applied the gold foil (bulkhead) and engine compartment ventilation measures to the car per stohr recommendations.
    In addition to the photos, i have some video of the car in action at hallett - http://vimeo.com/8279144
    additional items purchased for the car and included in the package are mk technologies parallel string toe bars, front and rear quick lifts, and chicken hawk racing digital pro-line tire warmers. The tire warmers are complete with custom fitted carrying cases and pit-bull stands for the controllers.
    stohr f1000
    • powder coated steel tube space frame
    • super strong, ultra-light fiberglass composite body and wings
    • full ground effects floor
    • quaife limited slip differentia encased in cnc-machined “stohr spar”
    • powder coated aero tubing suspension
    • machined aluminum uprights
    • wilwood 4 piston front calipers twin piston rear calipers
    • cockpit adjustable brake bias control
    • stohr specific machined floating rotors and hats
    • billet aluminum pedal assemblies, clutch, brake and throttle
    • stohr f1000 carbon fiber floor panel
    • steering wheel column mounted billet aluminum paddle shifters
    • ohlins st44 double adjustable dampers (compression & rebound)
    • hyperco springs 700# and 800#
    • hyperco/icp hydraulic spring perches (8)
    • bbs 3-piece aluminum wheels - 8.0 x 13 front, 10.0 x 13 rear
    • goodyear slicks with 1 weekend of use
    • jet-hot coated header
    • stainless steel lightweight muffler
    • custom aluminum radiator
    • setrab 45 row oil cooler
    • momo suede steering wheel with spa quick release
    • s.p.a, technique fire suppression system
    • fuel safe inc. Fuel cell
    • 2005 suzuki gsxr 1000 engine prepared by loyning' s engine service
    • stohr snorkel type airbox with latch system (black e-glass)
    • aim david video and data logging system with mychron 3 dash
    • sensors- wheel speed, oil temp, oil pressure, water temp, throttle position,
      steering position, lateral g, longitudinal g, beacon transmitter
    • chase pdr100 digital video recorder with cf card
    • 2 chase bullet cameras 520 line resolution
    • autotel rr710 radio system: Mounted kenwood tk-3140 uhf car radio with
      li-ion battery and charger, steering wheel ptt, mounted car antenna, kenwood
      tk-3140 uhf pit radio and headset with ni-cad battery and charger & carry case
    • documentation package, log book, etc.
    spares, accessories and equipment included in sale:
    • extra bbs wheels: 2 front (8.0 x 13) and 2 rear (10.0 x 13)
    • stohr transport wheels & tires
    • spare hyperco springs 800# and 1,000#
    • full car set of wilwood compound ‘a’ brake pads
    • new replacement forward splitter, side pod skid plates and skid blocks
    • goodyear rain tires (never mounted)
    • amb direct wired transponder
    • mychron optic lap transmitter (beacon)
    • flatshifter pro new in box (see www.flatshifter.com)
    • stohr lift bar
    • mk technologies f1000 parallel string toe bars
    • mk technologies f1000 front and rear quick lifts
    • chickenhawk racing digital pro-line tire warmers with cases
    • pitbull controller stands
    • misc thermal blanket & insulation items
    delivery is negotiable.
    Contact:
    Randy lamp
    479-903-9000
    my kind of place
    Circuito Do Sol Portugal
    Liked: 384
    Default trade possibility
    Nice pics.
    I'm getting out of street car into F1000.
    Would you consider trade for 2003 Z06 corvette?
    Thanx.
    maris
    Maris Kazia ,CEO
    EuroKraft Inc Racing
    Circuito do Sol
    Rogers Arkansas USA
    I'm not ruling out any trade, but already have an '08 Z06. Great car, but I only need one.
    Rogers Arkansas USA
    Offer pending. Thanks ApexSpeed!
    louisiana
    Default Sale Pending
    Let me know if the sale does not go through. I am ready to buy.
    Courtice, Ontario, Canada
    Liked: 145
    Why the Canadian McDonald's sign? Maple leaf in the middle of the golden arches. Just wondering, being a frostback and all.
    Stephen Adams
    RF92 Van Diemen FFord
    1980 Lola T540 FFord
    Rogers Arkansas USA
    Quote Originally Posted by old 59 View Post
    The original owner was a McDonald's franchise holder in Canada. I liked the look of the car and have left is pretty much as-is graphics-wise. The car looks excellent in person.
    Liked: 145
    Good answer, good answer. Yes, the car looks great in the pictures.
    Stephen Adams
    Rogers Arkansas USA
    Sale is complete.
    I'm delivering the car next week.
    Thanks ApexSpeed!
