Results 1 to 20 of 20
    Tacoma, Washington
    Liked: 210
    Default Reasons Why - 89SF Reynard
    Okay it isn't leaking. I mean we finish a race and the driver isn't covered in gas. So why in the heck should I go to the trouble of looking at the fuel cell enclosure more often then every 20 years or so??
    The picture doesn't do justice to the oily gop mess and tire turds collected. Would make a great fire feeder with plenty of air flow and no way fire suppression could reach it.
    Florance, AZ
    Liked: 33
    Crap! I thought mine was bad but your's makes mine seem pretty clean. But my cell is a replacement, so it's been apart at least once before. We use a good bio degradable cleaner at work - Biodyne - works real well, just did a final clean last weekend as I finally start putting my Reynard back together.
    John H.
    Reynard 88SF
    Tacoma, Washington
    Liked: 210
    AZ,
    One thing I'm going to do on the put back together is, lay a thin sheet of aluminum under the cell rivited to the sides (and taped) so those rails aren't 'digging' into the cell. The cell sags down into those areas and could cause some amount of fuel NOT to be available at the pickup. A piece of .059 (or so) aluminum should do it.
    Then drill a couple of 'small' holes in the sheet and the belly pan in case (hope not) the cell developes a leak. Better to have the gas on the ground then in the cockpit!
    North Eastern NJ
    We put a piece of fiber gasket material under in back of and in front of cell so that it would not chafe/rub against any metal. It's amazing the stuff that gets lodged in there. A 10/32 screw in the wrong place can kill the cell.
    We too are going to place a pliece of aliumiumn under the cell as the floor bows a bit under that area. Next season a new floow will be in order.
    Liked: 960
    Don Adams at Fuel Safe recommended I set the cell on a rubber mat to prevent abrasion damage to the bladder. I found some 1/8" thick closed cell foam rubber to put under the cell and part way up the walls around the bottom of the enclosure.
    Regards,
    Dan
    Liked: 1507
    Ensolite - an old US Army sleeping bag pad available at your local army surplus works well.
    Tacoma, Washington
    Liked: 210
    I found some 1/8" thick closed cell foam rubber to put under the cell and part way up the walls around the bottom of the enclosure. Regards, Dan
    I'm thinking the same thing on top of the aluminum flooring. Something that doesn't soak up gas On the other hand, you still need a way for water, gas or moisture to drian out too.
    Florance, AZ
    Liked: 33
    AZ,
    Mine already has a pan under the cell - thought it was "standard".... also drain holes. Like I said, someone has already been in there. Also has a nice fuel pickup inside the cell.
    John H.
    Reynard 88SF
    Florance, AZ
    Liked: 33
    Couple of things...
    I'm using aircraft Teflon cowl tape in all corners with Ensolite padding under - protection from rivets.
    Have a .060 neoprene cloth reinforced pad to go under the cell - safe for use with fuel.
    My setup looks not to be standard - Has a Fuel Safe cell with a real nice surge tank, also he fuel outlet is at the lower left rear corner of the cell.
    John H.
    Reynard 88SF
    Contributing Member SWMyers's Avatar
    Saline, MI
    Default Fuel Safe Cell
    The fuel cell sounds like a Keith Averill modification. My car (currently in his shop for frame repair) has the same setup. Keith told me he did a number of cars that way.
    Tacoma, Washington
    Liked: 210
    Quote Originally Posted by SWMyers View Post
    Yes, I talked with Keith. Your mods and AZ's sounds like the uprated Averill unit.
    Turns out he has a drawing for making the replacement cell but doesn't stock them and no dealer discount with Fuel Safe any more. Dang it!
    Did you guys take the filler neck off when you removed the cell? I didn't and it was a bit tricky to get out.
    Wonder if the 84 to 86 cell is the same as the 87 to 92? Maybe we can get a group purchase going
    Florance, AZ
    Liked: 33
    In talking to Keith before I bought the car it seemed that it had quite a few of his updates... one of the reasons I bought it!
    Fuel cell removal - yes, the filler tube was removed, there is a short neck on the cell it clamped to.
    The cell is in the car now while I do a final mock-up before final assembly... so it will be all apart again shortly. I'd be happy to give you the Fuel Safe Ser. #, could be they have records on it. Also would be happy to take some pictures of the cell & install if you'd like to compare... would have to wait a few days, I'll be out of town from tomorrow thru late Saturday.
    John H.
    Reynard 88SF
    Tacoma, Washington
    Liked: 210
    That ser. # would be a BIG HELP when you have time.
    louisiana
    To protect the cell I use .10 inch thick(approx) red rubber/fiber gasket material cut into strips that cover rivet rows ect.
    Glue down with contact cement or silicone and cover with real cloth duct tape--or something good.
    coat cell rubber with good rubber preservative
    1/8-3/16 drain holes--close to each corner and one in center.
    secure all fuel lines, filler neck ect so no flopping around goes on.
    (strain relief)
    Most cars I see have filler necks flopping around-scary-I make simple brackets and hose clamped or wire tied.
    The gasket material is from local rubber and gasket house.
    commonly used for flanged water/sewer fittings by local systems.
    David
    Florance, AZ
    Liked: 33
    Ser # is 200712, production date is 02/1994
    You can see how it fits, the filler & outlet.
    John H.
    Reynard 88SF
    Tacoma, Washington
    Liked: 210
    Thanks a lot AZ!
    Production date 1994? Hmm. sounds like somebody replaced the cell the first time about when it was 'supposed' to be. If Keith see's this, I wonder if he can tell if it was built to his drawing?
    Liked: 611
    Default fuel cell
    Rick,
    I had some cells made before I found out that they offered an inner surge tank pick up. And I'm sure that others took it upon themselfs to do the same.
    If there is a bolt-on plate, on the back side of the cell, than it may have one. You could always un-bolt it and take a look, or you may be able to see something by looking in the filler opening.
    Averil Racing Stuff, Inc.
    Ontario, Canada
    Liked: 95
    Default Fuel cell
    It would perhaps be better to drill out those rivets shown vetically in the pic and turn them around so they don't protrude towards the cell. Maybe too late but just to help. I also TAPED off the rivets and siliconed and used the semi rigid foam in the triangular features. Never had even a rub. Remember that it can get tight if you fill it and it sits in the sun etc.
    JIM (2006 GLC CFC Champion)
    Florance, AZ
    Liked: 33
    Rick,
    Mine does have the bolt-on tank, also a nice surge tank/pickup - you can also hear the balls for the check valves to the surge tank rattle when the tank is empty.
    John H.
    Reynard 88SF
    Florance, AZ
    Liked: 33
    Quote Originally Posted by Westroc View Post
    I thought about that, but decided it would be better to have the flush side out so it doesn't catch on anything moving around on the outside. The inside corners are filled with Ensolite (sp?) foam which is fuel resistant, then taped with an aircraft Teflon tape whose adhesive is fuel resistant. Nice and smooth. Bottom of the cell now has a .060" reinforced neoprene pad to rest on also. Sharp edges around the fuel neck and outlet are also now covered. Lot better then when I took it out...
    John H.
    Reynard 88SF
