    Senior Member Bob Coury's Avatar
    Jupiter, Florida
    Liked: 79
    Default Alignment Swift 88 SE3 FC-front sway bar in or out?
    Revised my original post:
    I never aligned a rocker arm car before. I removed the front sway bar before attempting to align it. Lowered the car back on level ground, now their was about 1/4" difference in length between the the front springs. Seems like the front sway bar was preloaded.
    Do you align a Swift rocker with the bar in or out?
    Bob
    Orlando Florida 32812
    Liked: 637
    remember >>> like eye know anything
    what tires are you running?
    springs? .....i dunno.....a set came with my car.
    front: 1/2 degree neg camber, 1/16th toe out
    rear: 1/2 degree neg camber, 1/16th toe in
    weight: 250 front 340 rear
    rake: front 1 & 1/16th inch, rear 1 & 3/4 inch
    set wings rather neutral...not much of an angle is needed IMHO because it's already a wing
    flavor to personal taste.........i guess this was what you were looking for
    Liked: 3855
    Bob,
    "It all depends", like Eye said.
    What springs?, what track? what tires?
    I'd say with Hoosiers on a CFC, a good starting point:
    Slight toe out in the front.
    Slight toe-in at the rear.
    -1 degree front camber
    -3/4 degree rear camber
    front caster around 4 to 6 degrees, mainly important that both sides are the same, whatever it is.
    3/8" to 3/4" rake
    I run fairly stiff springs for a rocker car (at least 800# at front) so my starting ride height for Road Atlanta, or RRR is around 7/8"
    Aim for hot tire pressures around 19 to 20 lb.
    Cold starting pressures in the 14-15lb range, sometimes the fronts as low as 13.
    Main element of the front wing angle of attack 0 to -1 degree
    Lower element of rear wing angle of attack = 0
    Upper element of rear wing 7 to 14 degrees. RRR=7 CMP=14
    Once you drive it. First thing you will "feel" is ride height. Make sure the tires are hot before you decide it's too low. I scrape a lot te first lap or so at Atlanta, waiting on the tires to grow and raise the car. If you are just tapping a bit a few places each lap, you are about right. If you aren't hitting at all, you are probably too high.
    Next you balance rake. e.g. If you have trail-brake oversteer, lower the rear.
    A pyrometer will give you some idea how close you are on camber.
    Number one rule: Don't chase bad tires. You have been putting this car together for a long time. Don't go out on some three year old ten cycle tires and scare yourself silly, nor make a bad decision about the set up.
    Jupiter, Florida
    Liked: 79
    Thanks guys.
    Mike: I learned my lesson years ago in my Hawke DL2 days-don't try to set up on bad tires.
    I just want to get in the ballpark and try to validate some existing data that conflicts with one another. I think I have 250 # front springs and 500 # rear. Pretty soft. I need to get them apart to look for markings or get them checked. Some data I have indicates front ride heights from 1.38 to 1.75, rear from 2 to 2.25" The Goodyears I have on the car now are about 1.5 years old, and I am just out to run to keep my license right now. I could not justify put heat cycles on a new set under the circumstances. Hope to have a new set for the following race.
    I am sure I will notice a big difference between the SE-3 and the 97 VD I got to drive in 2005.
    Hope to see you guys at Moroso, Sebring or Daytona this year,
    Jupiter, Florida
    Liked: 79
    Added to my previous post:
    Liked: 3855
    Leave the bar un-attached until you are done. Then attach it with no preload.
    The springs could be different lengths for a bunch of reasons:
    They were not the same length unloaded.
    They are different rates.
    One of the rockers was built different than the other.
    The car was way out of whack.
    Jupiter, Florida
    Liked: 79
    Mike:
    OR-I unknowningly rolled the car earlier in the evening so left rear tire was sitting on a little block of wood.
    Thats what I get for working on the car when tired.
    Thanks for all the help.
    Bob
