Results 1 to 25 of 25
    Senior Member Keith Robinson's Avatar
    Abbotsford British Columbia.Canada
    Liked: 87
    Post LeGrand Mk 21 FF front suspension failure.
    Racing at the weekend and the 'wheels came off' well only one actually!
    I don't know how to post a photo but the break was fairly simple.
    Where the top link is attached to the top of the knuckle the ball joint sits in a 'cup' that is brazed to the link.
    That part fatigued and broke off at the brazed joint! Interestingly the braided brake line 'tethered' the wheel assembly and kept it with the car (the bottom ball joint had sheered off due to the failure of the top link)!
    Luckily it happened in a slow corner and I didn't hit anything or anyone!
    So where to go for information on parts and information for this car. I've raced it for two years and I like the car, never had
    any prior problems?
    I've been on this site for over 20 years and this is the first time I managed to post a photo :-)
    Liked: 440
    Take the broken pieces off carefully and have new ones made. Not a big job. Similar to many formula fords.
    Graham
    Liked: 87
    Thanks for the reply.
    Can you recommend anyone in the North West that will 'make a new one'?
    San Jose, Ca
    Can the machined and threaded bearing cups be bought? Making a jig for that wouldn't be too difficult. I've made similar parts for my cars' front lower control arm. I'd braze the broken one together first, then make a jig, then make the little sheet metal parts and off you go!
    San Diego,Ca
    Liked: 643
    Default suspension
    Call Ethan Shippert at Sonoma.
    Roland Johnson
    San Diego, Ca
    Liked: 1101
    +1 for Ethan's work, but Mike Edick in Gig Harbor probably has the fixture to make them.
    mteracing36@gmail.com
    Petaluma, CA
    Liked: 705
    Thanks Roland, but I too agree with Dan on this one. Send it to Michael Edick. Not only does he likely have fixtures for it, but his work is stellar and his pricing is more than fair.
    Keith- I would use this failure as a solid indication that you need a full car set of suspension. I have seen more suspension failures over the past 5 years than I saw in the previous 20. All this stuff is just flat getting old. Years of internal corrosion, embrittlement from plating, a zillion cycles of stress, kerb strikes, off track excursions, overzealous applications of ratchet strapping in improper locations, etc etc. Just make it all new. It will likely cost you somewhere between $1500-$3000 depending on the complexity of the suspension. But like the old adage says “an ounce of prevention is worth a pound of cure.” The peace of mind of new wishbones and radius rods far outweighs the risk of tens of thousands of dollars of racecar parts, and/or your own physical well being. Those old girls have served their purpose. Time to put them out to pasture.
    Ethan Shippert
  11. The following 10 users liked this post:
  12. #8
    St. Louis, MO
    Liked: 111
    This is probably obvious but when you reassemble the suspension be sure to replace the already stressed brake line.
    Also, it may be prudent to replace the same suspension piece on the other side of the chassis.
    M
  14. #9
    Liked: 1101
    If I could add a little nugget to Ethan's post about replacing the entire set of suspension parts, Mike Edick worked for Red LeGrand for about 6 months before going to Cal Poly for his mechanical engineering degree.
    Mike said that Red was an admirer of Colin Chapman's "Simplify and Add Lightness" philosophy on his designs. I replaced all my suspension parts on my Crossle 25F because of age/fatigue concerns.
  16. #10
    St. Louis, MO
    Liked: 34
    Keith- I would use this failure as a solid indication that you need a full car set of suspension. I have seen more suspension failures over the past 5 years than I saw in the previous 20. .....
    I had the lower left wishbone on my 1972 Mallock collapse last year at Gingerman on the straight between 6 and 7. I opted to replace both sides, and will likely replace the uppers over this coming winter.
    Maybe take the good one off and send it to the fabricator and ask him to make two, one for each side.
  18. #11
    Liked: 87
    As expected lots of good information from 'ApexSpeed' members, thank you all!
    Researching LeGrand front suspension I've found there are two versions made over the years.
    One is a cup brazed onto the top link with the ball joint inside it and the other is a threaded link with a large Heim joint on it.
    The brazed cup is 'Lotus style' lighter but I'm not keen on the butt joint brazing (which is what fatigue/deteriorated on my car).
    The Heim joint version is heavier but looks stronger!
    I've received several recommendations/suggestions where to go for help; Mike Edick in Gig Harbor is closest so I'll try him first!
    Yes I do recognize that 50 year old Formula Fords are getting a little fragile! I also own an RF75 Van Diemen which appears to be built
    a lot stronger than most (but it was not one of Mr Firman's quickest cars!).
    Thanks again for all the input, much appreciated :-)
  20. #12
    Powhatan, VA
    Liked: 171
    Default axles
    another consideration for timing out is the welded axles common in the first generation of FF
  21. #13
    Liked: 87
    Default More LeGrand suspension info!
    Lots of helpful information from Micheal Edick and others, thank you all.
    I've concluded the Heim joint top links are the way to go for an upgrade which will be fairly simple and make camber adjustment easier!
    The bottom ball joint is more of a problem, the ball joint sheared off and I'm looking at a tricky repair trying to drill out the threaded piece. Replacing the knuckle would be best if I can find one, all suggestions would be appreciated.
  22. #14
    Montclair Ca.
    We run the ex Edick MK21 and it has different A-arms with a ball joint (like a
    crossle) on top and a heim joint on the bottom. We have had lowers made but not the uppers.
    Mike does not have jigs.
  24. #15
    Montclair Ca.
    Sorry, I meant 21. We have a MK27 as well. Senior moment.
  26. #16
    Liked: 87
    Quote Originally Posted by scott fairchild View Post
    Are you referring to the front knuckles in my photo?
  27. #17
    Powhatan, VA
    Liked: 171
    Quote Originally Posted by Keith Robinson View Post
    No sir. I was referring to the fabricated rear axles that utilize rubber donuts and U-joints. Just another consideration with age and fatigue of components. On the HFF cars, the youngest models are 53 years old. Some have had their axles replaced since new. Just like suspension or rubber donuts, if the axle breaks, it affects the broken car and all those in the immediate vicinity. Going to stiffer rubber would logically transmit more loads into those welds.
    Good luck on the repairs,
    Scott
  29. #18
    Liked: 87
    Scott
    The rear of my 1975 LeGrand Mk21 makes a lot more sense to me (design wise) with all Heim joints and CV axles!
    My car being more CF (only 50 years old!) rather than pure Vintage.
  31. #19
    Bay City, MI
    Sounds like a pretty clean fatigue failure. For parts and info, you might want to reach out to folks at the vintage formula forums or even try contacting people who've raced or restored LeGrands. Some guys on Apexspeed might have leads too. If you’ve had it for a while with no issues, could be worth checking the whole suspension for similar wear just in case.
  32. #20
    Liked: 440
    Those look like Triumph Spitfire or Hearld. Modified but that is another not a very big job.
    Graham
  33. #21
    Liked: 1743
    don't drill that out. Put a nut over it and fill the nut with Mig or TIG.
  34. #22
    Lincoln NE
    That;s a Spitfire upright
    Herald/GT6 has an adapter plate between caliper and upright
  35. #23
    Langley B.C. Canada
    Default LeGrand front susp.
    Hi Keith. I have a few spare Spitfire front uprights. Also some on marketplace from a guy in Delta who I don't know. He has a bunch of Spitfire parts including what looks like 2 complete cars worth. But for sure I can spare one of mine. How modified from stock Spitfire is it ? Unfortunately I still don't have my lathe etc. functional yet. Still trying to get a couple of new buildings up and things sorted out , machine tools usable.
    Hope you can find a reasonably priced and reasonably quick solution to this. I have not had the time to get out to any events this year. Life has become very complicated, just the opposite to how retirement is supposed be.
    Greg
  36. #24
    Liked: 87
    Quote Originally Posted by GreginCanada View Post
    Greg
    I know 3 Gregs in this area, can you text me or personal message me please and thank you!
    Or you can reach me through SCCBC.
  37. #25
    Langley B.C. Canada
    Sorry Keith, I expect Greg in Canada is not much help in figuring out who I am. The Greg you sold the Baxter to in Langley. I will pm you with my number. I am hopeless with texts, just call me.
