Results 1 to 14 of 14
    ohio
    Default Van Diemen 2000 Aim brake pressure mount location?
    I'm trying to measure brake pressure using the aim pressure sensor. However it doesn't clear the front ARB.
    Thoughts on how to solve this?
    https://www.pegasusautoracing.com/pr...asp?RecID=7070
    https://www.dropbox.com/scl/fi/6yxv62d058wt8qmwi36pf/IMG_2377.JPG?rlkey=a1e0uo1lsk2sqma94kuih8og0&e=1&s t=2qtqvihi&dl=0
    Liked: 1483
    Gets a little tight up there.....
    I did the following:
    I used a pair of these:
    https://shop.veracitydata.com/collec...t-3-8-24-ports
    And made a mount like this:
    And stacked the hoses on the masters.
    The mount is a 3d print with brass 1032 inserts.
    ohio
    okay that's freaking cool!
    Paso Robles, CA
    Liked: 316
    I made a bracket that clamps onto the rack to mount my brake pressure manifolds.
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
    Orlando FL
    Liked: 24
    Default great ideas
    My personal setup is very close to same as Davids, works great, sensors aim down with bleeders at top, no air pockets.
    Savannah, GA (via Montreal)
    Liked: 1006
    Best to soft-mount pressure transducers like these, on rubber blocks, with a short hydraulic pigtail "Tee-d" off the brake line fitting. Just be sure to fully bleed the pigtail so air doesn't get into the brake line. Unless you're using a pair of them to determine brake balance, doesn't matter if its in the front or rear line, use what ever's convenient.
    Petaluma, CA
    Liked: 705
    If you use AP masters, the reservoir is behind the outlet so there is no clearance issue to the FARB. Then you can use a banjo bolt with a pressure tap built into the head and thread the pressure sensor right into the banjo. A lot less potential leak points this way and the AP masters are really nice parts to work with.
    Ethan Shippert
  12. #8
    ohio
    Do you have any pictures of this setup?
  13. #9
    Liked: 915
    I've seen M10 banjo bolts with a tapped head but no 3/8". Where can I find some?
    Petaluma, CA
    Liked: 705
    Here ya go:
    https://www.summitracing.com/parts/RUS-R40505
    The description says "chrome" but they are actually a satin nickel finish. They look nice. I've used them on dozens of brake pressure setups over the last 15 years. I keep 5-6 of them in stock at all times just for this reason.
    This is an old pic with the old style pressure sensors, but you can see the AP masters, the banjo bolts, etc. And FWIW, the newer style AIM pressure sensors fit even better.
    Ethan Shippert
  15. The following 3 users liked this post:
  16. #11
    St. Charles, Illinois
    Liked: 222
    Question on the above picture. How do you bleed the air out of the sensors?
    Liked: 915
    Quote Originally Posted by BrianT1 View Post
    I haven't installed them on Rock's car yet but looking at the sensor and the banjo bolt as an assembly I don't think there will be much if any air to bleed. It should be very similar to a standard banjo without a sensor. I'll let Ethan confirm.
  18. #13
    Liked: 1107
    When did mine last, I bled the lines first, then filed the sensors with an eyedropper(recommended by TimW), gently tapping to make sure there was no trapped air. Worked great with a firm pedal.
  19. #14
    Petaluma, CA
    Liked: 705
    Never had an issue with air in the sensors. I suppose Dan’s suggestion of filling the sensor with a dropper first is a good “belts and suspenders” approach. But to be honest I’ve just put them in, bled the system and gone racing. Never gave it a second thought.
    Ethan Shippert
