Results 1 to 5 of 5
    West Union, IL USA
    Liked: 343
    Default lola brake and clutch pedal pads (340/440)
    Any chance someone has the pads that thread into the brake and clutch pedals lying around? They are just a 7/16-20 bolt with the pad welded to the head. Mine where modified by previous owner and the bolt cut off shorter and the edges of the brake pad were ground smaller as he was a big guy and had size 14 feet. Thanks for checking! Easily enough fabricated but if available would like to keep the car as original as possible.
    West Union, IL USA
    Liked: 343
    Default Bimp to top
    Just wanted to check one more time if anyone had some lying around? Any fabrication I do will look bodged so if you can help, let me know.
    Kip
    Mississauga, Ontario
    Liked: 942
    Kip
    I have a set off a 440 here.....somewhere. Let me look
    bt
    West Union, IL USA
    Liked: 343
    Default check PM
    bt
    I'm sending you my contact info if you come up with something.
    Thanks for looking!
    Kip
    West Union, IL USA
    Liked: 343
    Default Thank you!
    Shout out to billtebbutt for dropping a set of used Lola pedals in the mail to me from Canada...with no charge even for postage. Now that I have originals in my hand I can see that prior owner "Shaquille O'neal" had cut off half of the bolt length of the set that came on the car. As a "height challenged" individual there is no wonder I couldn't reach the pedals!
    BT: Thanks again, let me know if you ever need some help at Nelson, M-O, Grattan, or Waterford. Keep me posted how your 540 project is going.
  6. The following 4 users liked this post:
