    West Union, IL USA
    Liked: 336
    Default lola brake and clutch pedal pads (340/440)
    Any chance someone has the pads that thread into the brake and clutch pedals lying around? They are just a 7/16-20 bolt with the pad welded to the head. Mine where modified by previous owner and the bolt cut off shorter and the edges of the brake pad were ground smaller as he was a big guy and had size 14 feet. Thanks for checking! Easily enough fabricated but if available would like to keep the car as original as possible.
    West Union, IL USA
    Liked: 336
    Default Bimp to top
    Just wanted to check one more time if anyone had some lying around? Any fabrication I do will look bodged so if you can help, let me know.
    Kip
    Mississauga, Ontario
    Liked: 940
    Kip
    I have a set off a 440 here.....somewhere. Let me look
    bt
    West Union, IL USA
    Liked: 336
    Default check PM
    bt
    I'm sending you my contact info if you come up with something.
    Thanks for looking!
    Kip
