Results 1 to 6 of 6
Thread: oil leaking
    stockton, california
    Default oil leaking
    Looks like I need a new pan gasket, oil leaking in several places. I have not investigated it yet, but if I take off the skid pan will I be able to get at and remove the pan or at least replace the gasket? Has anyone cut their skid plate to take off just the part under the motor?
    Liked: 1102
    Before you start doing surgery, try to identify the source of the leak. Get a spray bottle, fill with water and a little dish soap. Regulate a compressed air source down to about 1 PSIG and pressure the air into the crankcase vent to the catch can. The leak sources should produce bubbles.
    Savannah, GA (via Montreal)
    Liked: 1006
    Quote Originally Posted by coleking View Post
    which engine in what chassis for a start?
    Liked: 340
    Does it really matter that you have a small oil leak? Could you not put some absorbent material under it.
    Liked: 2062
    One off-beat thing to check is the fuel pump gasket. Had the mounting ears on one bend once, allowing the center not actually touch the gasket ( never could figure out how that happened!), and had to file the gasket a bit to get it to seal. It took quite a while before we were able to figure that one out!
    Liked: 1102
    My recommendation for a bubble test with air applies to a FF Kent. One notable leak point is the mechanical tachometer drive if you have one.
