Results 1 to 10 of 10
    Windsor California
    Default Source of This Steering Shaft in a Van Diemen RF81?
    It fits between the upper steering shaft and the rack.
    The u-joints are getting loose.
    I assume it's from a production car?
    It appears to fit on a 14mm finely splined shaft at each end and is 308mm or 12 1/8 long
    Prescott, AZ
    Liked: 205
    Please pass along your search results for those who have these cars.
    Contributing Member Comp89's Avatar
    Ottawa, Ontario. Canada
    Default Steering Shaft in a Van Diemen RF81
    Check with Universal Racing Services: https://www.universalracingservices.com/
    J-Guy
    Windsor California
    I will for sure
    Windsor California
    Quote Originally Posted by Comp89 View Post
    I know they are a great resource for Van Diemen parts, I'm hoping to figure out the original source of the shaft.
    Memphis, TN, USA
    Liked: 436
    If it's a matter of loose U-joints, try installing new U-joints. Much cheaper
  8. The following 4 users liked this post:
    Contributing Member Roux's Avatar
    Connecticut
    Liked: 170
    Default Borgeson?
    isn't it from these guys? 9/16 will measure 14mm with some rounding up. The fittings then get welded to some tubing too make a custom length for the VD or Royale or whatever. Spline count options are also in their catalog
    https://www.borgeson.com/Steel-9-16-36-X-9-16-36.html
    Windsor California
    Quote Originally Posted by Roux View Post
    I will check it out and share what I learn
    Lincoln NE
    Assuming it's 9/16x36 spline, Pegasus has u-joints and stub shafts, so you could build one
    There's a chance it could be from an Austin Allegro
    That was a popular part for the Brit kit car world, back in the day
    Prescott, AZ
    Liked: 205
    Since Jack knight built the steering rack they may be of some help.
    Locating them might be difficult
