    Liked: 104
    Default CF minimum Weight and log book page number
    Hello, If someone can tell me the official weight for a club Ford that will run regional
    and possible vintage races I would appreciate it very much.
    1976 Zink Z10-c and 1981 Zink Z16 are the subjects.
    I don't have the patience for the online GCR any more.
    Thanks very much!
    Liked: 936
    Hi Skip.
    It depends on who is running the event.
    For SCCA, CF is a Regional class and final specs are determined by the Regions. It used to be the same as FF but with the radial spec FF tire adding 10lbs per car, I'm not sure if Regions/Divisions added that weight to CF or left it at 1100 with driver. Unfortunately, my Z16 hasn't been driven since 2009!
    For Vintage, Monoposto rules say the car-only must weight at least 950 but I know SVRA does their own thing, requiring 1125 with driver after session.
    Bottom line is that the organization will need to be contacted to determine how much lead needs to be loaded!
    Powhatan, VA
    Liked: 171
    Default vintage weights
    Hi Skip,
    I can't comment on the GCR page #, but vintage for CF depends on which group you're running with. Monoposto, who's rules most organizations traditionally used, stated that CF weight was 950# less driver and fuel. Now, many use an as raced minimum weight of 1110#, and SVRA is 1125#.
    Cheers,
    Scott
    Ottawa
    Liked: 1287
    For FF minimum weight, which depends on engine and gearbox, see GCR 9.1.1.B.20.A:
    20. Weight
    A. Formula F
    1. Ford Cortina Engine: 1060 lbs.
    2. Ford Kent and Honda Fit Engines: 1110 lbs.
    3. Cars running with a sequentially shifted gear box shall add 25 lbs. to minimum weight.
    As others pointed out, CF weight will depend on the organizing Region or sanctioning organization which stage the particular event.
    John Nesbitt
    ex-Swift DB-1
    Liked: 104
    Gentlemen, Thank you for your help. The additional information is helpful also.
    I needed the info for Motorsportsreg. Skip
    Ramsey NJ
    Liked: 33
    Default NEDiv CF Weights
    I just noticed that the NEDiv rules for CF are at 1100 lbs, Post CF cars are at 1110 lbs.
    https://www.nediv.com/images/nedivcl...Ford-Rules.pdf
    https://www.nediv.com/images/nedivcl...d-Rule-Set.pdf
    Alan
    It's not how fast you go.
    It's how well you go fast.
    Danbury, CT.
    Liked: 2194
    Quote Originally Posted by AlanVDW View Post
    Alan
    Same as FFCS.
