    Mokena IL.
    Liked: 52
    For Sale 1969 Winkelmann WDF-1 Formula Ford
    $23900.
    Just installed.
    New Master cylinders, New clutch slave cylinder. New Hewland side plate seals.
    New Tilton 7 1/4 clutch, New clutch disk.
    New throw-out bearing. New clutch clutch release cross shaft and bushings.
    Newly machined flywheel with new ring gear.
    New Pertronix 600 digital rev limiter.
    Additional set of steel wheels that have been checked and run true, will need cleaning and paint.
    Selling a nice WDF1, with lots of spares. A great car for larger drivers. This car has brand new bodywork and paint, and includes a fresh TPE engine with Scat crank, Ivey forged pistons and less the 3 hours run time.
    Bodywork is new, as is the windscreen and paint. Frame was blasted, inspected and powder coated. It has a tall rollbar and widened side protection bars. The former owner was 6'5" and fit the car comfortably.
    The engine was built by Pete Christiansen of Total Precision Engines. All internal parts were sourced from Ivey and include a new Scat crank, pistons and rods. Build and dyno sheets are available. New pertronix distributor and coil, along with spark plug wires and a new battery were installed. All new wiring was also completed.
    Hewland Mk9 in excellent condition, including extra gearsets. The drive axles were converted to Guibos, which are new, along with a spare.
    Calipers were rebuilt and updated Koni shocks and new springs were installed.
    Spares include a set of Panasport wheels, and steel wheels, new tires, brake pads, tune up supplies, distributor, complete exhaust system, shocks, springs, rotors and many more bits.
    $ 23,900.
    Member Banger Rally Man's Avatar
    St Austell, Cornwall, England
    Default Bodywork
    can you tell me who supplied the bodywork please
    Mokena IL.
    Liked: 52
    Default Bodywork
    I don't know. I think the current owner of the mold's lives in Colorado.
    Try this email address, ldebretteville@gmail.com to start.
    I'll see what I can track down the owner and let you know.
    Mokena IL.
    Liked: 52
    Winkelmann Parts Sources
    Jamie Stiehr
    Body Molds for WDF1s (& probably WDB1s, excluding engine covers) & suspension jigs for the same. Contact Jamie Stiehr at 303.886.2111 or via jstiehr@gmail.com
