SOLD 5/12/2019 to a great guy - new FF racer!
Just got this car back ready for the track. 1985 Swift DB-1 that was run very successfully up until sold to a new owner who developed serious health issues and was never able to run it. I picked it up as a freshen up project and because I only had two racecars at the time......................; )
I plan on having the car at La Junta May 3-5 to shake it down and get a new annual tech done. Looking to find it a new home. $12,900 at this point - more if I put a new paint job, etc. (See 5/5/29 post for latest sage update - motor inversion issues ; {
Car has just received:
New Pennon nose
New Braille Battery
New Fire System
New Hans Friendly Camlock Belts
New blue silicone water hose
New High Vis LED oil PSI warning light
New aluminum fire bottle cover, seat back, fuel cell top cover
New Camlock setup for nose and tail
New upgraded long Aurora Rod Ends for rear suspension allowing for additional camber when running the SCCA radials
New Fuel Pump
New Fuel Lines
New Fuel Test port
New Starter shaft bell housing bushing
Prior to being sold to the family I bough from - the car received:
Fresh off the dyno Jim Justice Motor - according to the records it has not run a race!
Scat Crank
Forged Pistons
Updated rocker stands
Hi-Tech Headers
Bosch Distributor, Petronix Electonics
Lightweight Drive Line components
Aluminum Diff
Gundrilled axles
Lightweight CV Assemblies
Drilled rotors,with aluminum alloy hats
Taylor Spark Plug Wires
Other items of note:
Double adj. remote canister Penske shocks
Protech Adjustable front sway bar
Cockpit adjustable rear blade style swaybar
Hypercoil Springs
Two sets of authentic Centerline wheels
Included spares
1. Nose and side panel
2. 4 extra wheels
3. 1 front and 1 rear upright
4. 4 control arms, three rockers - new or near new!
5. multiple gearsets and other gearbox spares
6. Inner and Outer CV joints,wheel bearings,sway bar parts
7. Drive belts ,clutch discs, master cylinders
8. Brake calipers,brake rotors and brake pads
9. Ignition parts,
10. Carb parts including gaskets, jets, linkages
11. Large assortment of rod ends
12. Barrel nuts for front and rear rod ends
13. Starter, Swift Starter extension shaft, new bronze bushings for bell housing end
14. Assortment of other swift specific spares
The negative about this car are just some cosmetics if you are picky - the side panels are 50/50 = look perfect at 50ft and 50 MPH - Nose and tail are excellent - just put your color on them.
Frame could stand painting - it is in good condition and floor is solid.
A Arms and rockers could all stand an afternoon of taking off, scuff sanding then a little satin black paint.
Come take a look this weekend at La Junta - I will shake it down and of course fix any bugs I find - I hope to have track video after that event.
Again - $12,900 is a lot of car and a ton of spares for the money - a proper setup Swift can run with anything out there - why pay more?
I have had good luck shipping across the country with a local husband/wife private contractor. Price is fair and they are prompt to CONUS.
Thanks for looking!
Jay Messenger
806-946-7252
muleshoeracer at yahoo dot com
