1) 711 block with good bore - not sure about deck height - $360.00
1) 711 block that needs sleeves - not sure about deck - $280.00
1) 030 block good for cortina it has squre mains and large lifter bores - $200.00
2) standard Feista blocks - $320.00 one SOLD
Head bolts long or short - $8.00 each
Piston wrist pins -$8.00 each
3) Standard feista crankshafts fitted with F/F pilot bearings but not lightened od balanced - $280.00
3) sets of standard con rods - $400.00 per set
2) sets of lightened and balance con rods - one set is 639 grams and the other is 630 grams - $500.00 per set
3) cast iron heads bare - $175.00 each
10) Rocker assembles complete - $250.00 each
9) Corrected rocker assemblies complete - $300.00 One SOLD
Many push rods - $5.00 each
6) rear main seal housings - $25.00 each
1) standard timing case cover - $35.00
1) timing case cover with mechanical tack drive complete - $60.00
Cam timing gear - $60.00 (Used)
Crank timing gear - $30.00 (used)
Autolite - FOMOCO distributors needing rebuild - $50.00 each
2) AC mechanical fuel pumps with adjustable inlet ports - $60.00 each
4) T-Stat housings $8.00 each TWO SPLD
Contact with E-Mail - ajp241 at yahoo.com or PM
any shipping is extra
pick-up in Hagertown, MD or Summit Point Motorsports park, WV
