    Member eflachbart's Avatar
    Vermont
    Default Dry sump scavenge 1/2 bsp to 3/4
    Ok so I have scoured Pegasus et al looking for a solution to this. My Twin cam dry sump pan has a 1/2 bsp hose barb fitting. The scavenge pipe on the titan dry sump pump is 3/4 od. This sounds like a fundamental question but will the 1/2" id blue hose that pegasus sells expand enough to fit over the 3/4" od pipe into the pump?
    Eric
    Lincoln NE
    Liked: 85
    If I understand you, would 3230-8-12AN and something like 3288-12-045 from Pegasus work? the blue hose will not stretch, sometimes it's enough fun getting it on the right size barb
    Vermont
    Not quite. The fitting on the pan is male, so the 1/2 bsp hose barb fitting is female. The scavenge pipe into the pump has no fitting the hose fits over the 3/4 od pipe and is clamped with an oetiker clamp.
    If I could find a female 1/2 bsp to 3/4 id hose adapter it would work.
    Vermont
    Got it.
    For future reference if anyone has to do this Pegasus has the parts
    1/2 BSP female to 12AN Male steel swivel
    12AN Female to 3/4 hose barb
    3/4 id textile reinforced hose
    Oetiker clamps
