Results 1 to 15 of 15
    Senior Member thunderracing91's Avatar
    WI
    Default Race car set up sheets
    Just wondering if anybody has some setup sheets that I can print off. I have some generic ones that I was using but it was geared more for a stock car. Anybody have anything for formula cars??
    Thanks!
    Andrew
    decatur, GA
    there was some a while ago. I may still have the pdf files that i got from prior iteration of this site.
    let me check tonite.
    Contributing Member Jonathan Hirst's Avatar
    Leduc County, Alberta
    Sure -
    2 Pager Car Prep sheet (inspired by C. Smiths books)
    Chassis Set Up Sheets
    Gear Ratio Charts
    Track Session Sheets
    Wet Race Check List
    Trailer Packing Check List
    Stapled together, it essentially makes up a "Race Weekend Package" (including a place to record Hotel room confirmations etc.) that stays together from when I start prepping the car until I file it away the Monday after I return home.
    When the results sheets and receipts etc are thrown in the file it makes for a good reference system.
    Unfortunately your profile does not allow me to email you directly - please email me and I will foreword any or all of the above to you.
    Jonathan
    Ferret Industries Archival site
    Ferret Industries on Facebook
    Basement Bookshelf FF/CF Scanned article Archive
    Member EMI's Avatar
    Central Arkansas
    Jonathan,
    Sounds as though you have a very detailed set up sheet, and I like the other things you mentioned. Having raced karts for many years we have set-up sheets for them, but I would be very interested in a copy of yours if you dont mind. Please e-mail them to; kbedens@hotmail.com
    [size=2]Monster Energy Drink, Motorex, Sponsorhouse.com, Hazardous Sports.[/size]
    Contributing Member Gary Payne's Avatar
    Columbia, Mo
    There are a ton of sheets posted on this site here: http://www.apexspeed.com/forums/showthread.php?t=12473
    Gary Payne
    St Louis
    OK - here you go. I wrote the above post from work so I couldn't post them earlier today.
    All the usual disclaimers apply. I am posting them in WORD format so you can delete/edit/add as you wish. Take my name out if you wish for I take no responsibility for copyright or claim of originality. There are no new ideas here. I use what works for me and often make extra copies to hand out at the track because someone will see you using them and ask for a copy. I mostly prep older cars so the list suits that application. Your needs may vary.
    The gear chart is nothing fancy, I just delete the ratio slopes from the correct chart so I can print out custom charts for the ratios I have for that car. Please alter the rear tire diameter value on the metrics tab to suit your application.
    Please pass these on.
    Unless I am the one prepping your car, I make no guarantees that these sheets or their content is 100% accurate or applicable for your application. Hopefully it will be an idea generator for you and you can tailor it to suit your specific needs.
    Happy Holidays everyone.
    Jonathan
    Last edited by Jonathan Hirst; 12.26.05 at 9:18 PM. Reason: Chassis Set up.doc - bad format repaired
    Senior Member Scotty's Avatar
    Queen Creek, AZ
    Thanks Jonathan!
    73 Lola T-340 #25
    Monty Python Addict "NEE!"
    SouthWest Formula Ford
    WI
    Wow thanks guys. This will help me out a lot next year!!
    Brown Deer, WI
    Liked: 47
    Andrew,
    Are you going to run the EWC series next year?
    Ian Lenhart
    Ian Lenhart
    Level 11 Creative
    www.level11creative.com
    lenhart06@yahoo.com
    WI
    Ian
    What does the schedule look like?? I havent planned out my year yet. I race motorcycles too so it kind of depends what dates will conflict.
    Brown Deer, WI
    Liked: 47
    The schedule is not finalized yet - see link for 3 out of the 4 weekends.
    http://www.apexspeed.com/forums/showthread.php?t=15345
    Send Steve Beeler an email to get on the mailing list for all the latest series news.
    Ian
    Ian Lenhart
    Level 11 Creative
    lenhart06@yahoo.com
    WI
    Looks like I will be able to make blackhawk and possibly RA. Is this series run under SCCA or is it a seperate organization?
    Brown Deer, WI
    Liked: 47
    The series is run under SCCA. The Blackhawk and RA event usully see about 30+ formula fords and club fords, so there is always someone to race against.
    Ian
    Ian Lenhart
    Level 11 Creative
    lenhart06@yahoo.com
  15. #14
    In an attempt to keep these files in an "editable" format, I realize that they may not appear correctly when you open them on your home computer.
    I just downloaded them to my work computer (3rd shift can be slow...) and noticed that on some files, the formatting of my headers was causing layout issues when viewed on a machine other than the one I use at home.
    I hope this didn't mess anyone up too much!
    The rose picture and the SIRS logo should be on the same line so you may need to reformat to straighten things up in the headers. All the columns should then sort themselves out.
    If it still doesn't work I have PDF versions.
    Jonathan
  16. #15
    WI
    All of them worked for me. Thanks John!
    Andrew
