My opinion, soon to be a letter to the CRB
Agreed 2, leave FV as is.
If you wish to have disc brakes, convert to FST.
Disk brakes in Formula Vee
I have responded to the CRB. Rather than reiterating my points again I'll just paste it in my post.
I would like to respond to the request for input for the inclusion of front disk brakes in the Formula Vee rule set as posted in the October Fast Track.
1. Allow front disc brakes in Formula Vee.
Based on the recent shortage of readily available brake parts for the currently used drum brakes, I believe it is time to seriously consider this. The most glaring shortages are backing plates and brake shoes that are suitable for racing.
2. If so, should the CRB allow ball joint beams to accomplish the installation or keep the original suspension?
I am aware of the discussion on this subject in the Formula Vee advisory committee. Their preliminary advice is to allow the disk brake conversion using the ball joint beam exclusively. There are cars whose design is not suitable for conversion to the ball joint beam (I will admit that mine is a primary example – so this would indicate my personal bias).
There are disk brake conversion kits readily available from large reputable aftermarket VW suppliers for the link pin beam that look as though they would work. One of the members of the advisory committee has already tested one of them. The one caveat with regard to the kit that looks most promising is that it would require the VW four bolt wheels rather that the traditional 5 bolt wheels.
There are a couple of issues to consider regarding this: There is a possibility that disk brakes would be a competitive advantage based on feel and reliability. If this turned out to be the case, then those with link pin beams should have the option to install them. There is also a possibility that the ball joint beam would be a competitive advantage based on it having more flexibility for camber adjustment. Unfortunately, there is no comparable solution for that with the link pin beam. Having not worked with the ball joint beam this is just conjecture on my part and both of these points are hypothetical, but I think worth discussing.
So, to condense and reiterate my points down to one sentence, as stated I would support the inclusion of disk brakes and the ball joint beam only if disk brakes were also allowed with the link pin beam.
Jim Oseth
Membership #288332
