Reynard FCs will be illegal in SCCA
OK, I'm on a rant!
I'm casually reading the September Fastrack, and all the proposed rule changes that my friend Richard Pare has proposed for the FC class. You need to read it, it's very extensive.
In 25 words or less, it's a proposal by someone closely aligned with an existing FC chassis builder to change the rules so no "new guys" can play in the FC sandbox, and bring in some 21st century technology.
That's a lovely little battle that has been raging for more than a year behind the scenes. The ramifications may seriously effect the competitiveness of FC as a class to compete with classes such as FB, and FE for entries.
Everyone knows i'm an old coger that can't afford a modern car, so in a direct sense I have no dog in the hunt. Yeah, yeah, I know, I have been the technical director of the F2000 Championship Series for four years. (That little series that has a couple of races every few weeks with more fast FC cars than the Runoffs could dream of.) What do i know about FC? In the minds of some grayhairs, if you weren't around before 1984 (pick a date), you can't possibly understand the "intent" of FC rules. But, i do know what the intent of these proposed changes is. ;)
I know I pissed off a SCCA steward in 1969 when i was at a autocross and he ruled that my 1200 cc VW had to run in a prepared class because I had Lucas running lights on the front, and they weren't stock VW items... I knew one day I'd have to pay. The September Fasttrack must be the warning that that day is near.
Back to the lead story. I'm reading along and low and behold I read that '87 to '90 Reynard chassis will no longer be legal in SCCA FC, if Richard gets his way.
He proposes: [FONT=ArialMT]
[/FONT]"The chassis and all bulkheads shall be of steel tube and panel space-frame construction only."
UH OH, i say. The front bulkheads of our beloved Reynards are cast aluminum!
So, in a zealous attempt to prevent new makes coming into the class, let's exclude a few hundred older cars. Pure flippin' genius.
So folks, you better read the September Fastrack.
OK, I'm done ranting... for a few minutes.
I'm going back to reading this new proposal to see what else pisses me off.
as far as the tubular space frame goes....
i would rather see carbon fiber tubs/safety cells for all new formula cars going forward
doesn't have to be expensive...could have a world class manufacturer spit them off a mandrel all day long
just saying...
Read the rules a bit closer....
[FONT=Arial]With all due respect, just because the cars were built, raced and homologated does not necessarily mean that they were compliant with the GCR. Remeber, homolgation does not insure that the car is compliant. Given the age and circumstances if the car does not comply by other means they should be grandfathered in.[/FONT]
[FONT=Arial]Please consider the following:[/FONT]
[FONT=Arial](red is new language, green is old language being removed)[/FONT]
[FONT=Arial]The chassis and all bulkheads shall be of steel tube and panel space-frame construction only. Forward-facing braces that protect the driver’s legs and feet shall extend from the front roll hoop to the front bulkhead. (The front bulkhead is defined as the transverse section of the frame immediately ahead of the pedals and drivers feet.) [/FONT]
[FONT=Arial]Explanation:[/FONT]
[FONT=Arial]SCCA rules on FF/FC chassis have always provided solely for a steel space frame. The bulkhead is defined as part of the frame in the existing FF rules (see the language stricken above which defines the front bulkhead as the transverse section of the frame.) Rule B.1 in FC states “chassis shall be of tubular steel construction”. Rule D.7.a in FF which governs FC construction states that “the chassis shall be of steel space-frame construction”. The new wording is simply a combination of both rules to keep the meaning as clear as possible that the only allowed construction is that of a steel tube space frame. The term "and panel" has been added since it is already common to reinforce the bulkheads with some steel sheet construction "gussets", etc. over and above the allowed bulkhead panels. [/FONT]
[FONT=Arial]Further, Rule 9.4.5.E.4 sets out roll cage material requirements. Such are defined as a minimum steel tubing size of 1.375 x .080. The roll cage is defined in 9.4.5 and includes a front and rear hoop. These hoops are both roll cage elements and thereby have to satisfy the material requirements of 9.4.5.E.4 [/FONT]
[FONT=Arial]I hope that this helps, No need to panic. [/FONT]
[FONT=Arial]John[/FONT]
Maybe ya shoulda thought about that
when you took the win at a National event in that vintage car earlier this year!
Can't you see what's happening here, Frogster?
You've got the other manufacturer's whippped into a lather with that win.
Now how the hell are they supposed to sell new cars to the masses (washed or otherwise), whole throngs ($5 word right there!) of which are clammoring ($buck fiddy) to buy into the latest techno trickery, when all of a sudden - WHAP! What what whaaaaaat?
It's all smoke and mirrors, no need to drop 60 large-ish on a new, ALL STEEL chassis, just do a Google Barn Search and hone in on those old, crusty and dusty Reynards out there, toss in a self built Kent, and whoop ass on all takers.
Like I said, ya shoulda been thinking about this crossing the line that day...
meanwhile, back at the ranch
After a brief flurry of posts by a few of us folks on the forum that are willing to discuss these things in the open, without gunfire i may add, interest in this issue will putter out and the real wheeling and dealing will go on behind the scenes by those that do not risk tarnishing their reputations by writing on forums. :rolleyes:
I can assure you the phone lines are just a buzzin'.
I hoped to point out that the new proposal falls short of truly clarifying the rules, and is just another patch on an existing quilt of confusing rules.
Read the 2010 GCR, read the proposal. Do not fall into the trap of assuming it was written in the rules a few years ago and it is still there. Read the words.
Form an opinion and send it up through the proper channels.
But... don't protest my Reynard front bulkhead next year. Because you should now know that it is really only a bracket. ;)
