I noticed a slight but very important
difference in the proposal for F600 that specifically addresses what I and many folks feel is a weak link in the stock Suzuki 1000 engine: connecting rod bolts.
The DSR community for the most part runs aftermarket con rods in their modded 1000's and does not see this problem.
The motorcycle racing guys have to my knowledge, and I know lots of 'em, NEVER seen this problem, most likely due to the fact that their engines do not live between 11 and 13k rpm. They have more off and part throttle time, and probably the biggest reason: the total weight of bike/rider is very close to half of FB car/driver.
I feel, and evidence points to a rod bolt breaking right at the con rod cap/con rod split.
I was on the gas when it suddenly let go, not downshifting, not overreving, just plain old hard on the gas.
All the rod bearings looked perfect, except the one that did the splits that is.
GC
Reply to Kake's request for info
Jake,
I haven't had your problem, but I will be happy to share my data if it helps:
Engine: Suzuki
Dry Sump: 2 stage Small Fortune design
Oil Tank: Peterson 7 quart
1) 34" and 38" in and out #10.
2) Never lost one
3) Spectro Platinum (in my experience, the best)
4) Water temps from 180-205 degrees f
5) No my data does not show this.
6) Stock oil pump and relief valve
Other possible issues: High vacuum on the inlet side of the pump (I have seen evidence of this problem)
Good Luck.
Bill Gendron
