Allow aluminum calipers in FC?
The CRB have recommended a rule change to allow aluminum calipers in FC from next year. Discuss and vote here, but most importantly...write the CRB!
PS - This poll records and displays who you are and how you vote, so please only vote if you are an actual or seriously prospective FC competitor.
If you must have a rule.....
If you want to keep out the most expensive systems - generally monoblocks - just take a page from the S2 rule and state that all calipers have to manufactured at a minimum from 2 body halves (their rule states split at the centerline, if I remember correctly), with an allowance for spacers to widen the caliper if necessary. Their rule of "grandfathering" specific CI calipers is to me a mistake, since it automatically outlaws any new CI designs.
Or just state that "monoblock" designs are not allowed and then define monoblock as being the main body being manufactured primarily from a single block of material.( Stating "primarily" allows things like small bolt-on bridge pieces that can be removed to facilitate pad removal).
Both AP and Brembo offer their 4-pot calipers with equal bores, though I doubt that either sells very many that way - all other things being equal, differential bore calipers will always be superior in race-long performance.
