Stressed floor pan on late model VD's
Several persons have recently pointed out to me that '98 and later Van Diemens continue the stressed floor pan aft of the main roll hoop to the rear end of the engine. If you have one of these cars I would appreciate any confirmation/refutation of this issue. Pics would be nice.
Thanks! Stan
Tempest in a teapot? (I hope....)
Daryl - you justify it based on the potential impacts of forcing compliance - what's to be gained here? Is this a genuine concern over FC construction or unintended consequences of the F1000 discusisons? Anyone have any original VD assembly drawings showing how the design was intended to be executed? Don't forget that what's on the drrawing and what happens on the shop floor are often two different things.
What if the club went back to correct their screw-up vis-a-vis allowing the original Swift design?
When I replaced the pan on my 94, I just copied the original (note - it could have been modified from as delivered, but I doubt it). Had anyone brought up this rule and made the appropriate clarifications, I'd have been happy to comply at that time. I would have made it two-piece and removable, and it would have saved me at least three engine removals to chase leaks and fix oil pump issues.
Right now, removing rivits and trying to break the bonds without $%#&ing up the whole mess would be a bit of a challenge.
Given the concern over full fields, anything that might result in taking cars out of competition while doing this kind of chassis work would be foolish. From an analytical standpoint, if the area in question does not provide a great deal of strength, then who cares? If it does provide a great deal of strength, then one could assume that the removal of it will eventually result in broken cars, which will need to be fixed, taking them off the track for a race or two. I'd contend that it's probably easier to add a couple of rivits and some glue to cars that don't have the panel stressed than it is to un-stress those that have it (obviously, it would be just as hard if one were trying to do the job properly as opposed to a retrofit).
From an enforcement standpoint, it requires getting the car in the air high enough to get one's head under it, verify the rivit spacing, and inspect for the presence of glue (assuming one could see glue through all the oily filth typical around that structure). Even for those with 6" spacing what do you do to verify no glue - have them drill off the rivits and see that the panel pops loose? I suppose the owner of a car that know's he is in compliance could protest every VD in the paddock and catch more than a few. And for the next couple of months he'd have damn few people to race with.
So it gets down to Van Dieman vs. Reynard, Swift, Citation, Tattus, Mygale, and a bunch of one-offs (and Citation, Tattus, and Mygale are awful close to one-offs). The difference in numbers is pretty staggering.
Of course, it also brings to question the homologation process.........
Single panel/stressed panel
I would offer this opinion. Take it for what it's worth.
The floor panel can indeed be a single panel, extending from front to engine, gearbox or wherever. HOWEVER, any rivets used past the rear bulkhead must not be closer than 6". The idea in the GCR is clear; they don't want the bellypan in the engine to be structural in the sense of adding rigidity to the chassis, thereby creating some kind of semi-monocoque. The pan is allowed to be stressed in the general cockpit area for the purpose of greater safety, and not to promote rigidity.
You can argue your points, and each may have some merit, but if I were on the court, this would be my interpretation. So if I found rivets closer than 6" in the engine bay, I'd call it a violation of the GCR.
Larry Oliver
