allowing both radial and bis 60 coumpound
Steve and others,
In regards to offering both radials and bias ply tires as the spec tire, I am on the Ad hoc committee and I pushed for exactly what you are asking for several times and was simply told no. I still do not know why. I thought it was a reasonable solution.
I am sorry I couldn't make it happen.
Skip Weld
Acceptance of "the" spec tire in FC
Keith,
In retrospect, you are absolutely correct. However, the fact is (was) that whatever was chosen, some folks wouldn't like it.
That's why the survey started with the question of whether the respondents wanted a spec tire at all:
"1. Do you support the idea of SCCA adopting a spec tire for FC?"
The majority wanted "a" spec tire. There was no way, no matter what was chosen, that it could have been everyone's 1st choice.
Someone pick the best tire at anytime
Let me run the best tire, and everyone else the worst crap tire. And like many people, the fast guys will still beat me, like they have
since 1968. Just run the car, have fun and go racing.
Kenneth
Garaged older suspension car likely equals old/tired engine
A thought that's not been brought up here........but maybe at least once spoken? and therefore discussed? among the now-over-and-done-with "committee" because a tire decision has been made. I say done-with because I'm guessing now that the tire thing is finished, at least for the forseeable future, the "committee" is disbanded ???
So a rule hoping to bring out older cars concludes bias over radial..... somewhat due to the suspension tune possible [or shall we say > impossible] for those older cars. Well one thing I believe that's true of a lot of the sitting-in-a-garage cars is the older/tired engines they've got [mostly tired Pintos would be likely]. I do not say Pinto here to again have readers go into Pinto vs. long rod vs. Z discussions.
Point #1 is: it would seem to me because of the engine sitting in the older car having too many hours on it, there's not suddenly going to be a great influx of these older cars to events merely because of a spec tire rule. Once the owners freshen the engine, then they might, at best, trickle out.
Point #2. Sure, sure certain people will be watching overall FC car counts for 2021 and 2022, etc........but there should be an attempt to keep track of - and mostly at the Club level - the count of "older cars" that participate on the spec tire.......because if there's no obvious rise to the number of "older cars" over the next few years, then the decision of bias - so as to not disenfranchise older cars - will have proven fruitless............so maybe there would be a need to have a different spec tire eventually...........which would then please at least the majority of those coming out.
"Committee" are you listening ????
