What do you mean they can't check them
In response to John's post about this subject, I think enough credit is not being given to our tech folks. These are the same people who mastered the art of fuel testing, right. And it is a complicated sampling, mixing with multiple reagents and reading IIRC color change, as well as reading a conductivity meter. And maintaining sampling containers properly to avoid cross contamination.
And someone thinks that these same folks can not read a simple light meter??
Come on who is zooming who?
EYE might be on to something
The CRB,BOD, et al are looking for alternate wording for GCR 9.3.32.B.2.
How about specifying that the rain light on a formula or prototype (sports racers but not a SRFx) must be red and flash. Seems to match human perception triggers.
How about this for 9.3.32.B.2
A red taillight that flashes at a rate between 4Hz and 8Hz (flashes per second) is
required on all Formula (open wheel) and Sports Racing cars. This light shall be mounted approximately
on the centerline of the car. Light assemblies are considered one light for the purposes of
this rule, irrespective of the number of individual lamps the assembly may contain.
This doesn't require Tech to do anything new other than recognizing a flashing red light (I believe 99% of us are capable of doing this). This eliminates the use of trailer marker lights which seems to be hot button for some AND allows some bicycle rear lights to be used which a sh!tload of racers did in the rain at Thunderhill in April.
All those in favor say EYE.
"It's a trap!" - Admiral Akbar
Here's the trap we've fallen into:
- Someone writes a letter to the CRB stating we need to change our rain lights.
- The CRB agrees, chooses an over-the-top FiA certified solution for ill-thought-out reasons already mentioned in this thread.
- The CRB/BoD publishes the recommended technical rule change to the GCR saying it will take effect 1/1/2024.
- The CRB/BoD tell members through questionable channels to write letters if the change isn't wanted; the decision has already been made, friends. We are being told to try stop it through a letter-writing campaign.
- We here discuss options to avoid a $200 FiA certified light because we're told by those same bureaucrats that if we don't like their wording and gizmo, we should recommend something else through said letter-writing campaign.
- We here come up with a gizmo and wording then write their letters.
- The CRB and BoD would supposedly then accept our lower-cost, certified gizmo and publish that in the GCR for 2024.
- We have tacitly accepted their premise that a rule change is needed, when it hasn't really been shown that it is needed.
- The trap closes and we're in it. Check and mate.
