Finally got a 3d printed part on a race car. My son designed and printed a catch bottle holder.
https://www.apexspeed.com/forums/att...id=93366&stc=1
Just remember to either make it air tight covering the choke shaft passage so the car will not start, or attach a long "remove before race"banner to it. I have seen more than one person not start a race because the engine would not accelerate with a cover on it.
James (or anyone else for that matter), have you created your own elevation track map? I'm trying to figure out how to use topographical maps to get the elevation of the track...it's not straight forward. If anyone has done this, I'd be thrilled to get some pointers!
it was mentioned earlier in this thread that GPS data from AIM can be converted into a file for 3D printing of the track, including elevation.
maybe just see how that is done and who has AIM GPS data for the track(s) you're interested in
Yeah I think I posted instructions? Took me forever to figure it out.
I did see that. My data doesn't do GPS so just brings in another level of complexity trying to get the data from someone else. Topography seemed to be a good alternative, but is proving challenging.
Depending on the track, you might find the 3d printer files on Thingiverse. I found Road America but didn't look for others. Mid-Ohio or Watkins Glen are probably on there. Blackhawk Farms or Putnam Park, probably not. ;)
Gents;
Thought of a retail idea. If you take a look at late model Van Diemens, there are aero thingies moulded into the coachwork that precedes the leading and trailing A-frame pickup points.
Now look at the mid year cars. Plenty of places to mount a well designed and produced piece(s) that provide a teensi-weensi bit of aero benefit. What do you think?
easy enough to do. Maybe a fairing in front of the cutoff switch. Made some A-arm jigs last week. Printing a catch bottle holder now. Next project is a box for all the electrical connections, the AIM tach amp, and the protection circuitry for it.
Here
Could be a money maker.
Yeah maybe. They take forever to print though. I made one of our local track with elevation.
Be faster for production to cut from wood with a cnc
They make nice keychains, too.
https://www.apexspeed.com/forums/att...id=93704&stc=1
Everyone knows the real money is in Turtles!
https://www.apexspeed.com/forums/att...id=93705&stc=1
Catch bottle holder and insulator for starter post
Filler attachment for a flow-fast pump. If you've used one of these, though they are easier to use than a funnel and jug, the 1/2" PVC pipe on the end of the hose fills a formula car filler neck sufficiently that the air can't escape well as the cell fills, often leading to a big "throw up burp". I designed this to screw onto a standard VanDiemen fill pipe (1.5" x12 TPI). The fuel flows through the 7/17 center pipe and exits about 1.5" down into the neck. The air escapes around the outside. if you overfill the funnel holds the extra until you crank it back into the jug.
Ignition Box - sort of inspired by the old Lucas boxes on a Cosworth DFX. Inside is the coil, six terminal blocks, the amplifier for the dash tach signal, and the protection circuitry for that amplifier. Replaced the mess shown in the other pic.
Last item is an input shaft mount for an Accu-level module. I have a lifting/leveling device I use to make splitting the car easy, but on re-assembly you need to get the angle between the engine and the gearbox just right. I put the level on top of the valve cover and read the angle, then put it on the input shaft and set the leveler to match. was always awkward holding the thing in place. This one has the splines to hold the adapter in place and magnets to hold the level to the adapter.
sent
Taking a stab at a few things, I've offered some of my prints (and capable prints) up for sale. For those of you interested in how I went about doing these, specifically the elevation tracks, shoot me a PM I would be happy to share my design process with you.
Easier to link my site rather than posting all the pictures here...
http://www.gladiatorroadracing.ca/3d-printing.html
Brackets for the crane parts, alignment bars, and my rear clip lifter/leveler. Most of these fit the clip-in 2x4 shoring mounts for E-track. All made from the cheapest Amazon PETG I could get as it took 2KG of stuff to make these and a couple of prototypes to get the dimensions right with the mounts. The crane brackets hold 80 lb.
I made up this little piece thinking of Iverson's comment about little aero bits, but also because I had this transponder cleaned off the car once and had to send it to Australia to get fixed. So this is a bit of a streamline device as well as a debris deflector.
I have a couple iterations to go to get it right, might have to slice it with Cura instead of S3D because they have a feature that changes the line spacing on curved surfaces to improve surface finish.
This was printed in PETG but I was surprised at how brittle this particular brand was - I got the dimensions of the little hook/tab at the bottom wrong and it snapped right off. So I might print the final version in either ABS and do an acetone polish, which really toughens the stuff up, or Nylon.
I also printed this attenuator for the nose box, basically to fit a pour-foam item that just fit too tightly. Well, I got the dimensions a bit too good and this one is even tighter! So I've been having to sand the crap out of it. I'd re-print it but it took about 3/4 of a kg of Atomic Carbon Fiber PETG and that wasn't cheap. This was made with a monster 1mm nozzle and has hexagonal infill and is incredibly tough. Sooner or later I'll make similar items for the area around the wing tube.
Here is an idea that might be useful for some of our 3D print enthusiasts. [I'll wager all your friends have some too...] :ha:
Flag mounts are available for full size flags, but few available for the smaller 12x18 inch flags. I've found aluminum brackets that hold 3 of these, and relatively cheap (5--6 bucks).
Unfortunately, they must be mounted with screws. This is something the county disapproves of on our light poles.
See photo 1:
https://www.apexspeed.com/forums/att...id=95015&stc=1
With a similar device, shown below, individual flags could be mounted using oversize "Jubilee" clips - aka hose clamps. They could be mounted to light poles, mailbox supports, trailer hitch, etc,. Several could also be mounted in combination if desired. The material should be UV stable. To secure the stick in place, a cotter pin would be inserted into a small hole drilled (after printing) through the mount and stick. This action would be performed by the individual consumer. The ID of the tube should accommodate the nominal 3/8 inch diameter poles (sticks) of these flags.
See CAD rendering:
https://www.apexspeed.com/forums/att...id=95016&stc=1
No FEA has been accomplished, just shade tree engineering and TLAR (That Looks About Right).
Gussets may be required or perhaps fillet the tube to the plate. Suggest some prototype testing might be in order. I'd be happy to participate.
My quick CAD file is available as a step/stl/etc if needed.
Cheers - Jim
BTW - I'd take quite a few at the right price point. My neighborhood has 13 poles just "begging" for a flag.
The trade here is strength vs material type vs material quantity. Kind of an interesting optimization problem.
Given what you see with wind load on a flag I'd probably do a "loft" from a big diameter to a small diameter (sort of making a volcano shape) before parting it at an angle and then joining it to the flat base.
Outdoor use would require ASA (a more UV stable form of ABS) or Nylon. Nylon is expensive and a bitch to print though.
An alternative would be to print a base for the aluminum mount to screw to (actually, I wouldn't use screws, I'd thru-bolt it with a captive nut and large diameter washer or a backing plate to spread the load through the plastic). T-nuts work too.
I'm thinking the mount would use less material and print faster and be much less susceptible to print direction and flaws.
I had some red PLA to use up and some time to kill before the turkey was ready so I made some more keychains.
https://www.apexspeed.com/forums/att...id=95143&stc=1
Here's what I've been printing recently. Been working at multi-coloured prints a little more
https://www.apexspeed.com/forums/att...id=95197&stc=1https://www.apexspeed.com/forums/att...id=95198&stc=1https://www.apexspeed.com/forums/att...id=95199&stc=1https://www.apexspeed.com/forums/att...id=95200&stc=1https://www.apexspeed.com/forums/att...id=95201&stc=1
This weekend I tried printing with flexible filament - TPE, which is a medium durometer urethane. Pretty good results - followed the instructions from the manufacturer and produced 4 perfect parts - likely the best I've ever made.
Two were pieces for a fridge handle - GE wants $100, have to buy the whole aluminum and plastic handle, as opposed to the $5 plastic piece.
The other two were sealing rings for holes in the roof of the MoHo.
I think I could print some simple seals and gaskets now - even a urethane bead on top of a cork gasket.
not at all. FAR easier than PETG.
What about winglets with Gurney lips?
I will get to wing endplates a bit later. next job is to re-make the inside cooling ducts of a RF90-96, making them out of about 4 pieces of ABS glued together.
A week of printing, I still have to glue in the wires etc. But it's better than I imagined. It's 16x16 inchhttps://uploads.tapatalk-cdn.com/202...0218f55f46.jpg
Should have waited till it was really done. Now it looks polished.https://uploads.tapatalk-cdn.com/202...5171e3dd11.jpghttps://uploads.tapatalk-cdn.com/202...a81372d7d9.jpg
Glad I didn't spend that spare money Granpa gave me on Neon School!
mid-90s VD inner radiator ducts. Multi-piece glued part. Checking interfaces with test prints now. Last iterations will include a good transition at the back to force air through the rad instead of going out the back and/or requiring a lot of foam fillers, and some fastener access for the bolts that hold the sidepod top on.
Started to build the molds for making fiberglass wing endplates.
https://www.apexspeed.com/forums/att...id=95795&stc=1
I recently bought an AIM steering wheel with paddle shifters. I can't use the paddles in P2 so I made a cover to seal the opening on the back of the wheel.
https://www.apexspeed.com/forums/att...id=95875&stc=1
Here's my latest iteration of elevation tracks. I added a white background to them with a multicoloured logo in the middle of the track. Been going through and printing all the tracks I've raced on.
Also, for something different, printed a Pikes Peak (haven't been there) track map with mile and elevation markershttps://www.apexspeed.com/forums/att...id=96287&stc=1https://www.apexspeed.com/forums/att...id=96288&stc=1https://www.apexspeed.com/forums/att...id=96289&stc=1
