More from Limerock press conference
I went to the press conference yesterday for the groundbreaking ceremony ( and free lunch catered by the Interlaken inn) and I agree with Mike, things might not be too bad if Skippy keeps his word. He was hedging his bets. The final plans are dependent on the lab results of core samples taken from around the track which will determine what they can and can't do. Nothing about improvements to the camping area, paddock or drainage issues.
Reading between the lines, ALMS seems to be driving most of these changes and why it's being done in the middle of the racing season instead of in the fall. Track is too fast for LP1 cars, no chance for passing. the new turns will add wide braking zones where passing can occur with wide run off areas if they screw up.
Highlights
The entire track will be repaved, not just the new sections. The concrete pads will be removed. More paved runnoff areas. Downhill section will not be changed.
Track configuration will be chosen by the promoter. ALMS will use the new configuration, Busch (nationwide) will probably use the Classic. Vintage might use one on Saturday and another on Monday.
The new sections will add 5-10 second to lap times, the length will remain about the same.
The chicane will probably still be there but probably not used.
The new west bend configuration will require the current berms and security buildings to be removed. registration will remain for now.
They bought the 19 acres of woods to the left of the infield entrance. They're going to put a new entrance with electronic ticketing machines through there by the ALMS race.
A spectator berm will be put in just before the bridge on the outside of the track new the downhill flag station. Doesn't seem too safe to me.
New Pit in areas by the bridge still under discussion.
The hill overlooking the esses will be cut back to the fence and a retaining wall will be put up. The swamp will be drained and a new section of track (optional) put there.
The hill overlooking noname straight has been cut back to generate fill for the bridge. More cutting will occur to give a view of noname from the main viewing area and to allow for a new straight. The camping area will be regraded to allow better visibility.
picture- Fitch, Ship, Posey
Most Recent LRP Track Map
The most recent iteration of the LRP track plans is here:
http://www.limerockclub.com/about_us/track_map.asp
Paving started at Club Skippy
The paving has started up at Limerock, the Club Skippy redo is in full swing. I hope the weather cooperates in June so they can do it right.
http://www.limerock.com/content/gallery-photos
mike
Which configuration for NARRC - Offs?
According to Skippy, the track configuration, Classic or slow, used for an event will be promoters choice. ALMS has already chosen the slow config, does anyone know which track will be used for the NARRC run offs?
I'm hoping for a faster, smoother classic configuration but no one asks me. Do we write someone and make our preferences known?
thanks
mike
