Your race car is NOT safe!
After re-reading the previous page, and in particular C.Shaw's comments in post #69, I'd like to add a couple of comments.
First: your car is NOT safe to race...even if it has passed current FIA F3 quasi-static and crash testing.
I say that because it is important to bear in mind that the safety standards which have been adopted by the Club (largely from FIA) only cover specific minimum standards. Standards which any race car with a running engine can easily exceed.
For instance, the FIA F3 front crash test is (IIRC) designed to decelerate a car hitting a solid, unmovable barrier at no more than 30 G's at 12 meters per second. That's about 26 mph. Go faster than that and the standard unravels. At more than 26 mph the nose collapses flat and damage to the tub/frame and your feet and lower legs starts, and it gets nothing but worse from there.
Building a "safe" car for ovals is not possible. You can increase the standard, but you cannot build a safe car for the speeds that even a 140 hp FC can routine achieve on an oval.
That is not to say that you cannot mitigate the danger, but let's not fool ourselves. You cannot build a "safe" racing car.
Second: the "no stressed panels" standard for FF, FB and FC were chosen for performance reasons, NOT safety reasons.
The most prominent safety shortcoming of a tube frame is anti-intrusion, since any frame's anti-intrusion properties are by definition non-isotropic. If folks seriously want a safety upgrade to those classes, then you need to support higher standards, but there is no need to go to stressed panels with their performance advantage. Steve Lathrop, Richard Pare and others have advocated increasing the kevlar requirement to 8 or 10 layers to duplicate the thickness of aluminum anti-intrusion panels. Do that while retaining the 6" spacing and you will have anti-intrusion protection comparable to the best F3 tub cars without the performance advantage that comes from stressed panels.
