Quote:
Originally Posted by
nulrich
I think the Citation has about the best side protection possible with a pure tube frame car. It should be very effective against blunt force impacts. The gaps between tubes do allow nose cones and sharp suspension components to penetrate. Although reinforced bodywork helps a little, I think we can do better. Unfortunately, the current FF/FC rules (as well as the FB rules) don't really allow any composite anti-intrusion panels (since, by their nature, they will "serve a structural purpose" and stiffen the frame somewhat).
I'm a little confused by that last statement.
I have a copy of the GCR from September of 2012 and it explicitly allows for anti-intrustion panels of the type the FIA is now promulgating for F4:
Composite anti-intrusion panels shall be attached with no more than eight fasteners per side. Fasteners shall be AN or superior grade of not more than 0.25 inch diameter. Two flat or coun- tersunk Mil Spec or SAE washers of no more than 1 inch diam- eter may be employed with each fastener. Ten fasteners per side are permitted if the panels extend to the front bulkhead.
Alright: as of that revision, it allowed fewer fasteners, but the rules of that date certainly did allow anti-intrustion panels that would stiffen the frame.
