Padding should be no brainer
Stephen,
is that your 'primary' racer or something else you have in the works? It clearly starts to address the real issue the rest of us are worried about, but not addressing. When it comes time to pad those bars you should cut the FIA/SFI padding so that the padding is narrow enough to appear the same width as the bars to your eyes and still be interposed between any allowed helmet trajectory and the bars. You could even make the padding taper from full width at the bars to something a bit smaller at the point where the helmet will contact. Spray Glue and tape or tie wraps and you are good to go
Cheers
Laughter is Good medicine :)
Brian ! Glad to hear you're on the mend. As for the brain damage, many would suggest that's a pre-existing condition :) Racers understand the desire to race, no matter the risk. Non-racers simply can not... Keep smiling, don't listen to the nay-sayers. Keep astounding them with your progress ! In the meantime, some sim racing will help satisfy that need-for-speed & help your 'motor' skills ;)
2014 Phoenix head surround
Here's one of our head surrounds for the 2014 Phoenix F1000. We used FIA / SFI approved foam. Built in the same manor as an F1 surround. Easy to remove and doesn't weigh much. Covered with Kevlar and a special resin specific to this use.
Radical Head Restraint For Sale
I previous posted a photo of the head restraint offered by Radical Racing. It is a very universal piece and could be used in formula car or sport racer. I hunted one down and had it shipped from the UK. The cost was $750.00 plus shipping and duty. I don't need it and will part with it for $700.00. Best Eric/esakuma@aol.com
