re-furbishing 3 piece wheels
Does anyone know of a media other than Soda that can be Safely used to clean wheel centers for NDT? I was considering buying one of the $200 blast cabinets from harbor Freight, and doing it myself, but it appears you need a Soda conversion kit to blast with Soda, and this is only offered with the more expensive blast cabinets. ---Jim
More-effective blind nut for getting the bolts out
HAHA... blind nut - in some cases I've fitted that description...:D
I thought of a better way to make this:
1. Get some pre-hardened hex steel (4140, 4340, etc.) and cut off a section ~1" long
2. Drill the tap size drill all the way through
3. Tap the hole all the way through to the thread size of the stuck bolts
4. Get a hard (GR8) bolt and a hardened nut, same thread
5. Thread the hex onto one of the stuck bolts, but not all the way to the wheel
6. Thread the hardened nut (to be used as a jam nut) onto the GR8 bolt
7. Thread this into the hex until it bottoms on the stuck bolt
8. Lock the jam nut firmly
9. Turn the hex (or maybe both the hex and the hardened bolt at the same time) until something happens.
This is easier to make than a bottomed out thread, and less likely to strip or jam together.
Mystery solve. Problem remains
I think I have figured out why I'm having trouble. I managed to get one of the bolts out. See below.---Jim
All the answers in one place.
[FONT=Verdana]To get the facts organized, I've redone EJ's original post with what I think are the answers given in the thread.
The final "truth" when it comes to the process and material(s) to be used to refurbish and re-coat racing wheels. [/FONT]
[FONT=Verdana]
Remove the centers from the rims –
Strip off paint, using " JABSCO PREMIUM or AIRCRAFT stripper, someone soaked theirs in ACETONE[/FONT]
[FONT=Verdana]Get them "blasted" by "SODA. I used ACRYLIC, However, EJ used sand at low [35PSI] pressure [ prior recommendation was NOT sand or glass]). [/FONT]
[FONT=Verdana]
Then to crack testing or x-rayed at a NDT* Service- OR AT HOME[/FONT]
[FONT=Verdana]
Paint them with " DP90 and EPOXY [some disagree on the epoxy] or RUSTOLEUM or use ALODINE. Carol Smith apparently says LACQUER ONLY.
Then CLEAR COAT for ease of maintenance , NO POWDER COATING. [/FONT]
[FONT=Verdana]
Afterwards, re-assemble with new Allen’s and metal locking nut (w/ Loc-Tite). [/FONT]
[FONT=Verdana]
SEAL with Dow Corning Silicone Adhesives/Sealant 832 on the crease AFTER the wheel is assembled ONLY[/FONT]
[FONT=Verdana]
Hardware: button head flange cap screws in steel with black oxide coating. [NOT stainless due to weakness concerns ] and Grade C lock nuts.[/FONT]
Bolt quality for wheel re-assembly
Fastenall has "grade 12" bolts built to ASTM A574 and ANSI-B18.3. Anyone know if these are adequate quality for wheel re-assembly?---Jim
I forgot to mention, they are metric, hence the 'grade 12' designation.
