SolidWorks Blocks for suspension design
Quote:
Originally Posted by
rmstringham
Ill add some advice for the OP...
Regarding your kinematics/moving in Solidworks, its really easy if your suspension is derived from a sketch instead of parts. That way you can visualize the motion without worrying about mates. Then when your kinematics are finalized, flesh-out the components and check clearances.
SolidWorks has this concept called blocks that makes linkage design easy. You take a sketch, that can be as simple as a line, and click tools>blocks>make. You would do this again for each control arm and the upright, then define mates between the appropriate points. When you're done, you can just click and drag a point on the suspension to watch it work. Click Help>SolidWorks Tutorial>Special Types of Models>Blocks for a better explanation.
Coming soon on my agenda is to get this to show me the instant centers and the roll center.
-Jim
