It should be switched through the master
I am so excited to send in my order for 4 of these for the run offs. Sounds like the $249 price that I heard originally has ballooned to 549?? Really think this is getting ridiculous, between the FIA rainlights and Flagtronics, that is pretty much1K per car for me to swallow. Wonder what the next thing to save us will be.
Brian.
Brian - look at the original FT unit. It is much less expensive than the remote unit and not that large.
Wire it through the master- it has a battery in its harness so even if power is disrupted, you can signal 'ok' if you crash. As I mentioned above, my FT unit shuts off with a 5 second push of a button. Worst case, it drains its in-line battery, but I think it automatically shuts down in thirty minutes.
I continue to be amazed at all the angst over this. It's easy to install in most cars: Yes, some need the remote one, but I bet fewer than you think. It does not have to be in direct line of sight- trust me, you'll see it when it lights up, even peripherally.
More important, when fully utilized it will save track time and make the racing safer for all. Ask anyone who has used the system.
1) Assuming the FT is hardwired to the car (through/using the master switch) .... you do not need the FT supplied battery. I assume the battery is included for installations that are NOT hard wired.
2) A proper built in battery controller/charger will prevent damaging discharge levels. Regardless, since the unit is hard wired, the condition of the battery is not relevant. Note how fully discharged infrequently used laptops always work once you plugin the charger. The quality/condition of the battery is not relevant with the charger plugged in.
3) The FT supplied battery is wired directly to the FT unit and is charged with power supplied by the FT unit. It has NO direct connection to the car's battery system. When you turn off the FT system using buttons. you are disconnecting the hardwire power and the FT supplied battery.
I’m going to say,this again,I’m not against this system,but when I wait 6 months for it and then install it ( Not Difficult ) then it doesn’t work like it is designed to says to me that it is not ready for prime time.
To mandate this system/unit at the Runoff’s where I have never seen it and it has not been tested and the drivers are not familiar with the new technology is not a good idea.
I will comply with the policy of the Club,but I still think that it is not a good policy.
IMHO
Tim MinorFc88:meatball::redflag:
The Runoff's is the perfect time to introduce the FT system.
A) The fact that a driver is not familiar with the system should not be an issue. At this time flags are controlling and the FT system is advisory.
B) Code 35 will applications probably be the only time the driver will need to observe the FT system. That will take place under yellow flags, so there should be plenty of driver bandwidth available to handle the situation.
C) The quality and quantity of RC and CS personnel will be the best you will see al year. Probably be staff assign just to the FT integration even at the corner stations. 7-10 days to note any issues with the FT system integration into SCCA operation procedures. Probably a work group assigned just for the integration task.
Ah... actually no, that's no longer the case (that FT is advisory).
Read the Runoffs Supps. The most restrictive flag condition, be it FT or actual flags held on the corner, will be the flag condition standing.
So pay attention. And READ THE SUPPS.
Me, I'm happy to have had a whole season to get used to it, and wish it had been in use at the Cat Majors.
But I 100% support my fellow drivers that we, those of us in the small-cockpit world, were ignored on our issues with the roll-out of this system. National doesn't care about us, and are happy to watch us leave so they can free up another session of track time.
Per the Runoffs Supps, section 8.2 - Flagtronics
Note also that a valid FT ID number is required for Event and Test Day stickers...Quote:
For the avoidance of confusion between Flagtronics and actual (cloth) flags displayed at the stations, the more restrictive flag condition shall take precedence...
There is also incomplete mention of electronic sign boards at corner stations. Needs more work, I think, in order to be internally fully consistent and eliminate the remaining confusion...
Tell me you're not going to the Runoffs without telling me you're not going to the Runoffs... ;) just kidding!
I guarantee that the use of FT will negatively affect the outcome of at least one Runoffs race, whether it's a mistake from RC, a false display (like Vaughan's checkered flag on the second lap at M-O), or someone ignoring Code 35. The appeals court will be busy.
A) The Flags are the controlling authority. As long as RC has their flag conditions correct, then any mistake with the FT system should not matter. The drivers need to have this fact clear in their mind while on track. Yes, this requires a little extra bandwidth, but by definition the quality of drivers at this event should not have difficulty with information that is not in agreement.
B) No Code XX during races, VSC only test and qual. A VSC of 45 mph follows a double yellow display. So again, plenty of bandwidth available for the driver to conform to the VSC procedure. The should be repercussions for a driver who cannot get the VSC right.
If you read the supps, what you wrote in A. IS NOT correct.
From the supps:
FLAGTRONICS
The Flagtronics electronic flag system is required for the classes listed below to enhance driver situational awareness. The Flagtronics system will be used to transmit flag conditions to in-car units and to communicate driver safety alert information back and forth with race control. In-car systems are available for purchase from www.flagtronics.com.
8.1.1. Flagtronics in-car units are required for the following classes: ALL RUNOFFS CLASSES For the avoidance of confusion between Flagtronics and actual (cloth) flags displayed at the stations, the more restrictive flag condition shall take precedence (e.g., Flagtronics shows green, but corner displays yellow flag – the condition for that part of the track should be considered Version 1 July 8, 2024 yellow). To maximize green-flag track time, race control may utilize a Virtual Safety Car (VSC) full course condition during testing and/or qualifying. The VSC procedure is designed to freeze and slow the field to a prescribed maximum speed to allow for expedited course clearing. The VSC condition follows the DOUBLE YELLOW condition rules related to passing. However, unlike a Full Course Caution condition, the field will not bunch up and the gaps between cars will remain consistent. For this event, the VSC condition procedure will be as follows:
8.2.1. Race Control will issue a VSC command to all corner stations via the flag net and to vehicles via Flagtronics.
8.2.2. Corners will display the sign indicating VSC, corner stations with electronic signal boards will display purple, and Flagtronics in-car units will display a purple condition, with instructions guiding the driver to slow to the prescribed speed.
8.2.3. Drivers will have 10 seconds to safely slow their vehicle to the prescribed speed of 45 mph or less.
8.2.4. Drivers are to maintain the prescribed speed throughout the VSC condition. Vehicles violating the speed limit will automatically notify race control through Flagtronics and be subject to penalty.
8.2.5. Once the course is cleared, Race Control will instruct each corner station to wave a blue flag in addition to its VSC sign. This is a signal to drivers that the course will return to green in approximately 10 seconds. The VSC condition still applies until the course returns to green.
8.2.6. At the appropriate time, Race Control will instruct corner stations to remove the VSC signs and blue flags, and Flagtronics will change in-car and electronic sign boards from PURPLE to GREEN, signifying the resumption of racing.
8.3. Because Flagtronics is at this event, information and data may be used as a basis for rules enforcement for all on-track infractions, including but not limited to VSC violations. The 8-digit Flagtronics FT200 serial number must be included in your vehicle garage through MotorsportReg. Participants are encouraged to update the firmware on their FT200 device via the Flagtronics Device Manager software (download at www.flagtronics.com) prior to the event to ensure proper functionality. Event and Test Day stickers will not be issued without a valid Flagtronics serial number on file
At least we know more about why they are so firm on the requirement for this year... they need to sell as many as possible before they consolidate classes and people don't race next year.
Ian I was concerned with finger/ knuckle clearance as well. However after 4 races it has not been a problem. I custom made the bracket myself and it was a very easy installation. The 2 bolts that hold the steering column on the Van Diemen are a perfect spot to attach a piece of custom bent 1/8 inch aluminum flat bar. A hammer, a drill and a vise are all thats needed
I got my unit as soon as they came out and iI love it! Not sure what all the fuss is about. I just paid $249 and if this is the large one I cannot imagine how it needs to be any smaller. It sure gets your attention without taking your eyes off the road. The first time I got a blue flag indication I looked in my mirrors and sure enough there was a real FA closing in at break neck speed. I really appreciated the heads up as I was about to move into his path to line up for the next turn. The only negative I can think of was at the June Sprints when I was ‘busted’ for not slowing down enough through a local yellow. I did slow down but 2 cars I was racing pulled away at an obvious higher speed and I never caught them again. They were not pulled over as I was. Big Brother is watching so beware. Race control knows everything now! Otherwise I agree this is a great tool! As a former pilot I love the situational awareness! I am sure it will save an accident or two easily paying for itself!
https://www.apexspeed.com/forums/att...d=112351&stc=1
Hartley,
Part of the issue is for us larger guys we have the steering wheel higher for leg clearance, and i have my shift lights where you mounted your flagtronics. If you weren't able to put it there, and your wheel was about an inch higher, where would you put it?
I started to mount my $550 dollar unit in my VD tonight. I think i found a place to put it, but it's unlikely I'll be able to press the buttons without removing the steering wheel. Now wire management, that's a whole different story.
Sure that makes sense with the wheel mounted higher. My shift lights are in my wheel so no issue. When you are on track there is no reason to push the buttons. Once you set the ideal brightness there is no real need to access the buttons. The buttons are so small I don’t think you could push the buttons accurately with gloves on anyway.
Working through similar issues to Speed Sport and CJ Jahn. Steering wheel as high as it will go and the VD front hoop limiting positions on the center of the dash behind the wheel except outside the cockpit with wires run through bodywork. I have three late model VD cars to adapt.
Thinking about mounting on the side of the cockpit so it is not blocked by hands and wheel.
1. Can the FT 200 be mounted vertically instead of horizontally?
2. The rf antenna is required to have a clear line of site which seems to contradict some of the mounting examples I have heard about for the VD.
3. The gps antenna is required to be 6” from another antenna and metal edges. Curious what defines a metal edge.
JM
From my understanding.. the 'regular' unit can be mounted in ANY orientation, but the screen display can only be read in 'regular' or Upside down (a setting in the FT APP). For the newer, small, 3 piece version, the display should be mounted 'horizontal', but can be either 'left or right. The remote unit with the RF antenna can be mounted in any orientation, but works best if 'generally clear' of metal - like you would not want to mount it beneath your seat against the roll bar. But against the front roll hoop.. near the top, works just fine for me. Just try not to have the ANTENNA directly in contact with the roll bar or any other significant chunks of metal. The GPS antenna can be mounted 'against' metal as long as it has a 'sky look' - with nothing significant immediately over it.. Like the regular gps mapping units most of us use to get to the tracks :-). My gps's (one for CDS and one for FT) are mounted directly (with TAPE) to the front suspension towers on my FV. 1 on the driver's side and the other on passenger side. Although both of mine are outside the bodywork, I've heard of many that mount on the frame under fiberglass bodywork successfully. Thankfully, that is easy to test just outside your shop door.
OH.. you would NOT want to mount the FT unit or the GPS right next to your RADIO antenna if the driver could transmit back to the paddock.
Another thing.. both of my gps antennas mount to the SIDE of the suspension towers, so they are not 'flat' to the sky - but both work just fine in that orientation.
"both of my gps antennas mount to the SIDE of the suspension towers"
Darn, what a good idea for FV.
Just finished installing my unit in my VD. 50 zipties, some fabricated mounts and an extremely sore back later it's done. Still can't really see it, but it's the best that i can do.
Two questions,
When powering it on in the shop, it only displays "sig". Is this normal? No mention in the manual and of course no phone number to call.
Also, i don't have wifi or internet in the shop. Manual indicates laptop must be connected to internet during a firmware update. Is this true or can you download the firmware file then offline upload it?
The problem I encountered was when I tried to manually turn it off it would not power down and all I saw was SIG and Off and it never powered down.
Flagtronics 804-915-7201
Hope this helps,mine is unplugged till I get to the Runoff’s so they can fix it
To power down, you have to push and HOLD 1 or both of the front buttons for about 5+ seconds - eventually it SHOULD say 'powering down' and turn itself off.
Yes.. the SIG display is just saying that it is NOT receiving any info from the master FT. Can't imagine why they didn't put that in the manual. I'm not sure about the app, but when it comes up it ALWAYS attempts to contact 'home base' via the internet and offers to update the APP software if an update is available - that is NOT the device firmware. There is no further info available (IIRC), until the device gets plugged into the laptop using the USB cord from the main device unit (I have only the original single unit). I'm not sure when the app checks for any updated device firmware, but it's likely it doesn't check until it can read the current version from the unit. Most cell phones have a 'HOT SPOT' option. It should be easy to connect the laptop to THAT WiFi to get everything going. If you don't have a hot spot option, you COULD roll the car over to your house and get internet that way... or you could use one of the MANY options available (via Amazon, etc) to EXTEND your WiFi signal. My shop is about 1/4 mile away from my house and I was finally able to extend from my house (using 10baseT cable) to a CPE transceiver at the house to connect via WiFi with a companion CPE unit at the shop (supposedly good for MILES under the right conditions). At the shop, it's another 10baseT cable to connect from the CPE unit to another WiFi access point to provide the shop with full wifi service. Cost for everything was about $200 IIRC - I did this nearly 10 years ago and been working great since that time. It's not 'full speed' compared to my inhouse wifi, but it's good enough to watch TV in the shop .. except that I DON'T watch TV. Tried it and can't work on the car and watch TV at the same time... would never get any work done :D.Quote:
When powering it on in the shop, it only displays "sig". Is this normal? No mention in the manual ,,,
One would think all of this information would come in an instruction manual for a system that is ready for prime time
Half the stuff we buy nowadays only has on-line manuals, no hard copies. This will likely be online also.
I did receive an email back from Flagtronics regarding the powering off of the remote unit.
They confirmed the remote units do not properly shut off, even after pressing the button for 5 seconds.
The only option is to remove all power and disconnect the auxiliary battery.
I was told they will let me know when they have a solution, which implies they don't have one as of now.
Therefore, when mounting your remote units, make sure you have easy access to the plug to the auxiliary battery. Looks like it's going to be standard procedure to have to plug and unplug the battery each session. :mad:
Might be handy to wire it through a switch?
Did they state that you need to use an aux battery if hardwired?
The instructions say that the aux battery will keep the unit powered for 15 minutes after the main power is cut. It is used to locate the car when the main power is cut, either in the event of a crash or when the driver gets out in the pits or paddock. I take this to mean that both are required. The original unit can still be turned off manually with the top button.
Gang,
I'm Collie King with Flagtronics. The Power Off issue on the FT-RD Kits is a software fix and it will be ready prior to the Runoffs. Once the fix has completed testing, each owner of the FT-RD Kit will get an email with instructions on how to update to the latest Firmware (I will post those here as well). In the meantime, if you want to review the latest Product Manual, you can download it from our website: https://flagtronics.com/pages/downloads.
I'll do my best to keep up with items posted in this thread as we build up to the Runoffs. I will personally be at Road America starting on Friday, Sept. 27th. I will be setup at Tech in the Garages. Please feel free to stop by if you have any questions or just want to say hello!
Collie
Collie - thanks for chiming in, glad to have you hear - and I desperately wishing your stuff were deployed faster, would probably have saved me going through a second round of a protest right now for bad officiating at the July Cat Majors!!! I made sure to emphasize to BOTH SOMs that I missed my Flagtronics display...
Anyway, as I've been an early adopter (of the regular FT200 unit) and presumably have missed most of the updates released this season, is it generally a safe bet to drop in the latest firmware from your above link into my unit now, or should I be waiting for local support at RA, or...?
Which 8-digit number is the correct number to identify the unit - I have an 8 digit number on the main antenna, and an 8 digit number on the display itself, both that begin with a 2. Which does SCCA need?
For those of you with the FT-RD Kits, please submit to the SCCA the 8-Digit Serial Number printed on the FT-RCV Module. It's the one with the QR Code and starts with 2000. The Serial Number on the FT-RD Unit, which starts with 2100, should not be submitted to the SCCA.
https://www.apexspeed.com/forums/att...d=112480&stc=1
Vaughan,
We are finalizing a new and much easier process for using the Flagtronics Device Manager software to update the Firmware of both FT200 and FT-RD Devices. It will allow you so pick a "series" specific firmware for the update. As we have many customers that race in multiple series like Trans Am, ChampCar, WRL, SCCA, etc. this will allow drivers and teams to update to the proper "series" firmware before such events. This will be ready for public release in a few days and I will post about it on this thread. SCCA will also email all registered Runoffs teams/drivers when the new process is ready.
Collie
I’m going to say this again.This is Not a well planned idea by Flagtronics or Scca.I am going to show up at the Runoff’s,the biggest race of the year with an untested product that the Company has limited information on and they have provided nothing in the way of support.I have it installed in my car and was told by Flagtronics engineering to disconnect the battery so not to drain the system and there were No clear instructions from them or the Club about which number to put in for registration. I hope they’re will be someone there to Help straighten out this situation for all the people who have installed these systems.Will Flagtronics be available at the Runoff’s for support.I hope so ???
Tim MinorFc88
Tim,
I rarely engage in online discussions of this type, but I feel compelled to address your concerns about the Flagtronics program, which was announced over 14 months ago as a partnership between the SCCA and Flagtronics to improve safety. I personally emailed you on July 29th to offer my support and included my cell phone number for you to call if needed. Additionally, a printed product manual that covers the installation details was included in your FT-RD Kit.
While I understand your frustrations, I want to clarify that we have made every effort to provide information and support. Although specific guidance on which serial number to use for registration was not initially included in the manual, I addressed that question in a previous post earlier today in this thread. Flagtronics is committed to ensuring all users are supported, and we will have support available at the Runoffs.
I will personally be attending the Runoffs starting Friday, September 27, and will be set up at Tech in the RA Garages. I encourage you and anyone else with questions or issues to come by, and I will be happy to assist.
Best regards,
Collie
I certainly hope it is sorted out soon.
A program launched 14 months ago should be plug and play by this time.
The FIA rain light was a plug and play. Buy it mount it and you are good to go
I have repeatedly e mailed Flagtronice Customer support with two simple questions:
What is the POWER draw for the remote display unit. It took 2 tries to finally get a complete answer. The first answer was 12v or 5v usb.
The second question was what provisions for mounting the remote display exist ( thru holes in the box to bolt it in place, tapped holes or what) never did get a response to that one
Thank you for your feedback and apologies for the delay.
The recent firmware update for the SCCA is specifically to accommodate the purple Code 45, which is unique compared to Code 35 or Code 60 used by other customers. The newly deployed updating process will be posted in this forum later today for all Runoffs Participants. It will be emailed to all Runoffs Participants next week and posted in other groups elsewhere, like Facebook, so please spread the word when you see the posting.
Regarding power requirements, you are correct, the both of our In-Car Devices can be powered by either the 12V flying leads or a 10W (5V x 2A) USB.
Could you please clarify if you’re asking about the FT200 or FT-RD model for specific mounting options?
Lastly, here is a copy of our latest Product Manual. This may help answer some of your questions as well. https://drive.google.com/file/d/1Rfn...ew?usp=sharing
Best Regards,
Collie
