That's my concern with the size and closeness of the 2 buttons. Responding when gloved....
Yes - $549+12.94 shipping = $562.93 delivered. I don't believe there are any add-ons.
You'll need to add your own power connector, mounting parts, and a pile of zip ties ;)
They include Velcro for the display. It's very small and light.
My concern is how I'm going to mount the RF unit with the antenna exposed since my whole shock cover removes as one unit.
I'll have to research if it can stick out the side.....
My AIM GPS receiver is under the shock cover and works fine. I'm hoping this unit can be mounted similarly.
I've got a few projects ahead of this right now.
My RF antenna ended up just under the overhang of my carbon upper body, and didn't seem to really have any problems with that...
I've been working with the flagtronics a lot over the last 8 months including CAN integration into an AIM MXS unit.
I'll try to answer some of the questions that seem to be floating around. My experience pertains to the original FT200 with combined display/brain so I apologize if any of the info I provide doesn't translate perfectly to the new separate display unit.
Antenna Reception is overall pretty good in my experience. I've run the unit at Sebring, Road Atlanta, Road America, and Mid-Ohio and had no issues to speak of. My unit is mounted entirely under a removable fiberglass panel and there doesn't seem to be any interference to speak of.
Medical Alarms can be overactive with stiff suspension cars, especially formula cars, so the developers have released a version of the firmware that ignores some of the vibrations that tend to set off the high G alarms that the device might interpret. This had definitely been a problem at Sebring, but my devices were flashed with this firmware recently at Road America by one of the devs and so far so good. I believe as long as you have updated your firmware after 4/22/24 you should have this improvement but I am looking into that.
Buttons - In a situation that raises a medical alarm on the device, pressing either button will indicate to the officials that the driver is okay.
CAN Integration has been really simple from the Flagtronics side of things. Obviously all of our cockpits are tight on real estate, so I actually decided to just bury my head unit and all of my flagging information comes up on my AIM MXS dash. I've used the CAN data to trigger icons and alarms based on the flagcode being received, so a FCY will cause my whole dash to go yellow and indicate a FCY for 5 seconds. This also applies for other major flags like red flags, black flag all, and checkered. Additionally, I am able to feed the flagcode data through to my Smartycam and show live flagging on my video feed, which is super useful for reviewing incidents.
I'll be at Summit Point with FRP from Aug 16-18 if anyone has any questions or would like some help in person.
All you need to do it yourself is a Win10/11 laptop, an internet connection and a USB cable. The instructions are on the FT website.. but you might have to search for them. Just download their software program and install it. When you RUN that program it will log into their website to find the latest version of firmware. Connect to your FT unit (plug the USB cable into your laptop) and the program will update your device for you. It's reasonably intuitive.
The windows app (FT Device Manager) can be found at
https://flagtronics.com/pages/downloads
I met with their dev the next weekend at the Trans-Am/SVRA/FRP speed tour, he happened to find me so it was mostly luck on my end.
I've sent him an email looking for clarification on whether that FW is available through the setup app or if it is still being withheld at this time. I'll let you know when I get an answer.
Can the Flatronic be integrated with a Aim Evo4 on a FF/Honda?
JM
Should have specified - We use the G dash in all of our late model Van Diemen - it is not a color display but the warning lights are color and message screens can be tied to the warning lights.
Gents:
My Stack wiring harness connectors are watertight. Are these?
https://www.apexspeed.com/forums/att...d=112305&stc=1
I have an Aim Evo 4s with a formula wheel. Is there a way to buy the cheaper flagtronics system and then run the lights and message through my formula wheel display? I have yet to see anyone do this so I am not sure and would appreciate any help or suggestions
the car is a zetec FC, not sure if that matters.
thanks,
I can't be sure, but I doubt it.
Having seen Flagtronics in action in TAm, my concern with running the info into an existing dash would be whether Flagtronics messages would "take over" the display for extended periods of time, leaving you otherwise blind regarding your vehicle?
(edit: flagtronic messages just don't pop up then vanish moments later as some people might think)
Brian- you have a VD- look at the picture in post #89. I mounted the original model in less than an hour- it works great.
Although Necessity is the Mother of Invention, I most certainly hope someone from Flagtronics is monitoring this thread. Responding to “potential customer feedback” is how you stay in business. If you are out there:
- Provide an option of removing the mounting feet from the aluminum extrusions for formula cars;
- Tapped 8-32 or 10-32 holes on all sides;
- Watertight all electrical connectors. We race in the rain, open cockpit.
Does the Flagronic ever display text or is all the information communicated through colors? The reason I'm asking is that my uncorrected close up vision would preclude my being able to read any text.
I think some of the conditions do have a letter or two, but not many... like Black Flag all...Yellow has a "Y" that I recall.
It will give you letters BF, FCY, SLO, G, Y, R and probably more in addition to the colors. It will start a timer when you enter the pits. The 'SLO' tells you if you're speeding in the pit lane, and if you are going too fast during a 'code 35' situation. It is all logged and monitored in race control. They know exactly where you are on track or off the track including how far off (and in the pits and paddock), how fast you are going, and what the G force was if you crash.
It's a pretty nifty system, especially when everybody on track has it.
Not sure you should use the words "used to". Just think about the google ads that show up when you mention something in front of Alexa or near your iPhone. :D
Not when you go off-track out of sight!! This seems to fix that - though I don't wish to test it... LOL
It also avoids confusion trying to identify which car is off in a barrier and partly obscured... which otherwise can easily take a lap or more to resolve...
I installed the FT-RD and powered it up and everything worked.I then tried to power it off and it wouldn’t power down.
I called Flagtronics and they said they needed to do a firmware update and they will have that available at the Runoff’s.
You have to disconnect the small connector that goes to the auxiliary battery or it will just continue to display.
So much for having it ready ?
Tim MinorFc88:yellowflag:
At least the previous versions (the original single unit) will continue to display for about 5 minutes.. or about the time it takes to run the battery down. In my case, I DISCONNECTED the line to the battery (a simple connector) so that it DIES when the ignition switch is shut off. I will need to reconnect it for any events I attend that actually have the FT 'in play'.. only the HST's or Runoffs. The battery is there to keep the FT unit functioning in the event of a crash with loss of power to the unit. It would allow the signal to continue to race control for an additional ~5 minutes after the crash. You can shut it down manually by pressing BOTH buttons for about 5 seconds .. or maybe 10? I disconnected it because turning the switch on activated FT IN MY SHOP - continuously keeping the battery pretty exhausted. Disconnecting it allows the battery to retain at least some of its charge.
WTF! I'm working on my install now. The battery is going to be under my seat, so based on this I need to remove the seat and fire bottle cover to turn it off until the Runoffs? What the hell needs to happen to waive the requirement for this years runoff?. This is beyond stupid at this point.
It doesn't turn off when you press a button (or both buttons) for 5 seconds? Mine does.
May I assume the unit is had wired to the cars electrical system?
If so would not the status of the system battery be irrelevant? When you energize the car you also energize the FT unit. I personally see no need for the battery or the need to turn the FT off. There is no way I am going to remember to turn it off.
If what I have stated is true, then there is no rush to upgrade the software for this one issue.
The unit is Supposed to power down after 15 minutes,it was Supposed to be turned off manually by holding the Top button for 5 seconds,neither worked.
I’m not against this system,but implementation of this,untested before the Runoff’s is not a good plan in my opinion.
Tim MinorFc88:yellowflag::yellowflag:
I said long ago that it was not ready for prime time.
Now the unfortunate folks that have had to purchase them for the Runoffs are getting screwed.
Come on sending a product out knowing that it will not work properly????
What kind of company is this???
And so it doesn't, what exactly are the negative consequences of this issue is to the normal on track function of this system?
You guys are trying to make an issue out of nothing. Sound like someone is still a little unhappy with the requirement to have the system.
https://www.apexspeed.com/forums/att...d=112318&stc=1Jay have a look at my installation it may work for you.
https://www.apexspeed.com/forums/blo...3-92d175ede3ebhttps://www.apexspeed.com/forums/blo...b-8807430e614ehttps://www.apexspeed.com/forums/blo...f-4640e3f2c716
