Pardon my lengthly questions
In the Penske's disqualified, Abel still out thread there is much talk of rules enforcement. I'm starting this thread as an SCCA scrutineer with 3 really basic GCR rules with the question of how should they be enforced.
(the GCR entries have been shortened for clarity and space concerns)
1 - 9.3.29. IDENTIFICATION MARKINGS
Each car shall carry identification markings per the sections listed below; and any markings required by the
Supplemental Regulations.
C. SCCA Logo
Each car competing in an event shall display the official SCCA field logo (see figures 4 and 5) unobstructed
and prominently on both sides of the car and adjacent to the side numbers. A third logo shall be displayed on
the front of the car unobstructed and prominently near the front number.
Question - Should the SRF3 on the cover of the GCR be penalized?
2 - 9.3.22. FIRE SYSTEM
All cars shall be equipped with an On-Board Fire System except T3, T4, STL, Spec Miata, B-Spec, C-Spec and
Improved Touring.
A. On-Board Fire System Requirements
It is recommended that all cars employ onboard fire systems that meet the following requirements:
• Systems certified to SFI specification 17.1 or 17.2, or
• Those listed by the FIA on Technical List No. 16
The following information must be visible of the unit:
• Certification label
• Capacity
• Type of extinguishing agent
• Weight, or volume, of the extinguishing agent
1. The fire system cylinder shall be securely mounted in such a manner that it can be checked during
a technical inspection and may be removed for weighing periodically for compliance to full weight
shown on the cylinder. (Weight is without valve assembly.)
6. All fire systems shall be serviced according to manufacturer’s specifications.
Question - Should a competitor be allowed to run if it is obvious that items 1 and/or 6 are not met? Or should it be noted in the log book to be fixed by the next event? Or?
Keep in mind that an SFI 17.1 bottle needs recertification every 2 years and and replacement every 6 years. An f'ing expensive undertaking.
9.3.35. MASTER SWITCH
All cars, except Touring, B-Spec and C-Spec, shall be equipped with a master switch easily accessible from
outside the car. It shall be clearly marked by the international marking of a spark in a blue triangle and
mounted in a standard location. Off position shall be clearly indicated at the master switch location.
The standard locations shall be as follows:
A. Formula and Sports Racing Cars–In proximity to the right-hand member of the roll bar, but in a location
so that it cannot be operated accidentally. It can be mounted on a bracket welded to the inside of the
upright member or mounted so that the operating lever or knob is outside of the body panel immediately
in-board of the upright member. This is the standard location on Formula cars built to the Constructor’s
Association requirements for Formula 1.
Question - Again, allowed to run? More importantly, how many of you meet this one? Crossles have/had a "bike cable" that ran from the upper right roll bar down and around to the master switch on the left side of the dash. Someone removed that on my Crossle.
Should the GCR be enforced without question with maximum penalties? Most every item in the GCR is protest-able. Do you have a monochrome SCCA patch on your suit, Nope? Protest-able, penalty depends on the steward.
My opinion - we're all here to HAVE FUN. Enforcing obscure rules is NOT FUN. If your car is unsafe, I'm going to ask you to fix it or I'm not going to let you run. I really think the GCR needs some cleaning up.
So What do you think?
