Originally Posted by
mikey
The function you described is called latching but I thought the behavior was programmable on the AiM so that the output can be momentary or latched in which case the specific part you’re trying to replace may not actually perform the complete latching function on its own. Can you still power the wheel and check the signal wire to the component you want to replace? See if the signal is momentary or latched. If the signal is latched then a regular relay is all that is. If the signal is momentary then the relay is a latching type.
