Looking for a small electric fire suppression system for an open wheel car, that won't break the bank.
any ideas
thanks
Dee
any ideas
thanks
Dee
Same here, or was. As I refurbish my car I realized my fire bottle was way out of date. I wanted something smaller but the price was pretty steep so I ended up with the same thing at just under $500, available from a variety of vendors.
https://www.firebottleracing.com/
I think you can get that in an electric activation as well...
Take a look at this:
SPA 17.2 system
This is from Pegasus but you can get it from other companies.
Not too expensive and uses NOVEC so no worries about freezing.
I think SPA is now owned by Lifeline - the SPA bottle is the same size as the old Lifeline.
Most SCCA regions will allow bottles if you weigh them and have pressure.
Before my annual I weigh and take of picture of it on the scale.
Pressure gauge in the green
I set one off accidentally and had it recharged by Stable Energies in NJ.
I did buy one of my bottles from them (they had to special order) and they did a recharge and recertify for around $130.
They also recertify HANS.
ChrisZ
When I restored my Anson I needed to replace mine too. Electrical is what drives the price up. I ended up with the $1200 lifeline system. I really found nothing else I thought could work. It did come with everything needed for a complete install. Tubing, fittings, switches and control box. Good luck.
We did the SPA FIA 2.25 Kg electric for a vintage Atlantic. The Lifeline looks like a good option, similar look to the old bottles.
