Performance? Thoughts??
to be clear, original "Formula Mazda" or "Pro Formula Mazda" ?
Is the question 'Which one is faster?' Or is the question 'Where are the highest concentration of each model located?'
Original Formula Mazda. Not PFM
QUOTE=Lotus7;675009]to be clear, original "Formula Mazda" or "Pro Formula Mazda" ?[/QUOTE]
All of the above. Looking for general feelings from people who have driven both.
QUOTE=CGOffroad;675010]Is the question 'Which one is faster?' Or is the question 'Where are the highest concentration of each model located?'[/QUOTE]
Driven lots of both styles.
To be really fast in Formula Continental requires technical savvy, ability to sense the difference between mechanical and aero grip, smooth/precise inputs, and conservation of momentum. Owner operators that succeed usually have an above average ability to engineer their own racecar.
To be really fast in Original/Standard Mazda requires a 5 gallon jug of 87 octane, a cowboy hat, and an ability to smile while sideways at 100mph.
They’re both fun and rewarding in their own way. If you have a gang of FM’s in your neck of the woods John, you would have a hard time beating it in the fun-for-funds department.
FM.....fast means one knows how to make 'em slide in the corner..........faster in a straight line than most any FC without trying too hard
FC.....can be better/faster thru the corners than FM for many a driver if car is set up well......not quite as fast in a straight line in general but in FM draft it's a big help keeping up
So, the deal generally is FCs don't like being near FMs on track because the FC will all too often find the FM holding them up barreling into and through a corner and if the FC can pass 'em that way, the FC will get passed by the FM on the next long enough straight.
Lather rinse repeat
